27th March 2018, 19:32
Fantastico!!!!!!
Bet you had a big grin on your face
27th March 2018, 19:37
That works ......
27th March 2018, 19:38
It was more a sigh of relief ! It does actually go together !
27th March 2018, 19:55
Awesome! The devil will be in the details, as always.
Looking really great!
27th March 2018, 21:20
The rear end will to mount up to the chassis. A few simple brackets welded the chassis and matching brackets welded to the original steel tube structure of the rear end will secure it in place. The front end will need more work to mount it. The doors are simple but require the hinging method to be worked out.
27th March 2018, 22:03
Shouldn't be too horrible to fab some tubing for the front.
Hinges, etc. will be easy enough for you as well.
In all, a bit of time is necessary. Looking splendid right now!
27th March 2018, 22:53
Big Cheese
Superb
29th March 2018, 04:53
Lucky – I know you did your homework before buying the body shell, but that really has worked out very well.
30th March 2018, 07:12
I know it’s early stages but - bl@@by hell looks wicked.
Thanks for sharing
1st April 2018, 21:56
Not much progress this weekend other than to make a small repair on the lower chassis rail and tidy up some of chassis where panels had been attached. I need to redrill my hub adaptors to the correct PCD before fitting the wheels and lining up the body.
2nd April 2018, 13:43
Looks excellent!!
4th April 2018, 11:58
hi lucky, tried to contatc you. did you get my messages?
4th April 2018, 15:20
No I didn't, send a pm.
9th April 2018, 22:40
Had some larger 185/80 - 15 tyres fitted to the rear wheels. They fill the arches really nicely, just waiting on the machine shop to finish modding my hub adaptors so I can bolt them on.
Once that's done I can line up the rear end accurately and make some bracketry to hold it in place. The front end will require considerably more work but I'm quite happy with progress so far! Photos to follow.
9th April 2018, 23:26
Eagerly awaiting the pics...
10th April 2018, 11:23
Hi lucky have sent e mail can you check pleas. Thanks.
12th April 2018, 22:20
Wheel adaptors came back today. I've only offered one of the rear wheels up tonight but it looks just right. I'll get the others mounted up and I should be in a position to finalise the rear body fitment over the weekend.
Also ordered a 15" wood rim steering wheel of a similar design to the original TR. I plan to make the interior look like the original cars did back in the 1950's.
14th April 2018, 18:00
All the wheels mounted up today and offered the body work up again. After a lot of jiggling around its all sitting pretty square over the chassis. I've made some brackets to attach the rear end in place and welded these to the chassis. I'm making eight attachment points which should be plenty once its all bolted down. Front end and doors next.
16th April 2018, 21:23
A couple of weeks to Stoneliegh , there's a slim possibility it might be on the road by then !
16th April 2018, 21:37
Big Cheese
Wow that would be some going
Pics, we need pics!
