21st June 2014, 22:37
You are 100 percent correct!
We need mind bending exercises to keep ahead of the game I think.
I seem to thrive on them!
Not sure where I would put that Jaguar tread plate though??
Where would you put it?
22nd June 2014, 12:45
Sunday
Regardless of all my other projects, the XK does take priority, so I spent the day finalising the bonnet ready (almost) for painting.
[IMG] [/IMG]
[IMG] [/IMG]
[IMG] [/IMG]
[IMG] [/IMG]
22nd June 2014, 21:25
Well, you are doing a great work, and it is very interesting with your updates!
Keep the good work up Scottie!
22nd June 2014, 21:34
Scottie - All your prep work will really pay off when the green paint goes on.
I like your mini van.
Have you seen the VW Campervan "Tot Rods"?
I'll try to find a link to one that I think you will like tomorrow.
22nd June 2014, 21:53
I'm sure you are right Paul, I've just left you a pep message on your page!
Stick at it!
23rd June 2014, 11:16
Thanks Paul!
It did put a smile on my face too!
23rd June 2014, 20:06
Monday
Today I worked on the horn and fan as well as other fiddly jobs.
At the end I of the day I now have a working air horn set, and a working fan.
I have not yet fitted the temp sensor in the rad hose, but the setup still works, as I can dial up any temperature for it to kick in between zero and 120 Centigrade.
There is a chap called Mick O'Mally who is also building an A 352, and some time ago I went to see it.
He is making a really good job of it too, and I was impressed.
While I was looking at the dash, I noticed a small black button, and enquired
as to what it was, and was told to press it and find out.
So I did, and the ensuing air-horn blast almost blew me out of his build shed!
I WANT ONE!
He told me the button was a Lucas Land rover one, so now I do have one, and at the moment it sits on the dash top. (As I don't yet have a dash)
A friend of mine came round and asked the same stupid question I had asked,
and I gave him the same answer Mick had given me, he pushed the button
with the same result I had! He also crapped himself.
Good job all round. Thanks Mick!
[IMG] [/IMG]
[IMG] [/IMG]
[IMG] [/IMG]
[IMG] [/IMG]
25th June 2014, 19:39
Talking about getting the car nice and low, I'm glad I did, but like everything else one does, it has a knock-on effect.
I looked into trial-fitting the doors yesterday, and when Chris designed the neat door hinges, they were at right angles to the body-curve of the side of the car.
Because I have lowered mine so much ( I cut two inches off the lower sides) this has had the effect of putting the hinges out of line, and they are now NOT at right angles to the car.
I can re-design and re-weld, or the option which I am hoping will work is to drill more holes in the hinge and shim them up to get the doors correct.
I have no pictures of the hinges yet, but here are two pictures of something else, can anyone spot the difference?
One car is an XKSS looking as it should, the other one is modified and looks like mine will. There are no prizes so don't ask!
(WCA) :-)
[IMG] [/IMG]
[IMG] [/IMG]
25th June 2014, 21:07
A narrow door?
25th June 2014, 21:12
Just about Gary, because my windscreen does not come all the way round the sides, my side window will go forward a couple of inches to compensate, although the door will stay the same size if you see what I mean! (That was the best I could do in Paintshop Pro)
Well spotted !
27th June 2014, 15:14
Today
The last couple of days, I have been busy with some of my other projects, also, cutting hedges, mowing lawns and admin tasks.
But today I really wanted to get more car done.
Although the windscreen surround is "finished" and virtually ready for painting,
there is one finishing touch I will do to it before it's painted.
On the Spitfire screen-top, Triumph saw fit to put a strip of aluminium, which would take all the hammer and battering putting the roof on and off would give it.
My screen surround is made of mild steel, and if I did not do something similar,
the paint would soon scratch off, and it would start to go rusty.
Of course, a big no-no.
For weeks now, I have been searching for an off-cut to cap the screen top
with. But instead of alloy, I will use stainless steel.
This should polish up like chrome, and the more hammer and scratches it collects, the better it will look.
I finally found what I was looking for today, and started to fit it.
It is ideal, as its only 0.65mm thick, so it should be easy to work it to shape.
(Famous last words!) A quick pic, then back to the workshop.
More later.
[IMG] [/IMG]
27th June 2014, 17:45
Later today
Well I went back and cut the strip to shape, and have shaped the rear of it which was straightforward enough, but by tea time I felt like I'd had enough
of it.
I will have to figure out the best way to shape the front over at 45 degrees.
I know it will be difficult as the steel has stretched slightly, making more problems, but I will get it right eventually.
( He said with not too much conviction!!)
If I can do it, it really will finish the screen off a treat.
[IMG] [/IMG]
[/IMG]
[IMG] [/IMG]
27th June 2014, 17:47
Somehow this pic fell off the end
[IMG] [/IMG]
28th June 2014, 07:06
Scottie - I know my head hurts working out things for my own build.
But I just sit here with my jaw dropping at the things you manage to fabricate for your build!
Your car is going to be amazing.
28th June 2014, 08:00
You are too kind Paul!
Your skill level is such now, that you only have to think of what you want, and presto, it IS. You can create it.
You are limited only by your imagination, you are in a higher gear now, and your car is thundering along. I am so pleased for you.
Believe me, your car will look so unique, no one will see any imperfection there may be.
28th June 2014, 20:12
Did a bit more to the stainless screen top today, and think its improved it somewhat.
I was going to rivet it to the screen frame, but think I will bolt it on
using stainless nuts and bolts to give a more professional look to it.
[IMG] [/IMG]
29th June 2014, 13:32
Finished off the stainless screen top today.
The front bending process was not as bad as I thought.
I polished it up a bit afterwards, I will drill the holes and fix it to the screen before removing it for screen painting.
[IMG] [/IMG]
[IMG] [/IMG]
30th June 2014, 15:25
How do you manage to achieve such an excellent finish on the stainless parts, Scottie? Do you use a bench top grinder with polishing wheel? Really impressive......
30th June 2014, 17:16
Hiya Retro,
Glad you are impressed!
In a word, "Yes" I do have a buffing wheel, or rather, I have three, rough, medium and fine (for the shine!)
I stick them in and old drill held in a vice, and polish things that way.
I also have some of that stuff that looks like grey soap, which you must have to get the finish.
Well today I finished off the stainless strip on top of the windscreen frame. At least, I hope I have.
In the event I did not rivet it on, or use nuts and bolts, instead I drilled and tapped out the holes, so I could screw the bolt directly into the screen top.
Even this operation was not without its inherant hassle, somehow
I managed to snap off the tap in one of the holes!
The swearing could be heard from afar............
I ruined two drill bits and a side cutter tool totally trying to get the bloody thing out.
In the end I ground down a 4mm screw flat on the end, and with much anger and violence, smashed the broken tap end out that way.
Thankfully, there was enough of the hole left intact too re-tap,
(after a trip to buy a new one) so I got around it that way, but all this extra work does not get the build done any faster.
I bolted the thing on with dome headed hex stainless bolts.
I need to rub down the screen frame and chuck some silver paint at it now!
One more step closer...........
[IMG] [/IMG]
[IMG] [/IMG]
