29th July 2014, 07:48
Bang tidy...
29th July 2014, 12:30
Tuesday morning
I took the small fan out of the car, and fitted the beefy one on steroids.
I was lucky to be able to use the brackets that were in place already, with a bit of twisting, re-drilling and so on, the cowling is in a good solid position, and the fan works well without fouling the sides etc.
I do admit, I feel much happier with such a robust unit in place.
As I said before, there never was an overheating problem anyway, but it is always nice to know that if you are stuck in heavy traffic during a heatwave,
The fan is going to whack the temperature down in a hurry when it kicks in.
My thanks to Landmannn, and Oxford for their constructive criticism, which is always welcome.
I also fitted both doors back on the car, and will now start the long tedious
and difficult task of shimming them up to fit as best I can.
I know how hard its going to be, because I spent an hour doing it first thing this morning and got so peed of with it, I left it, and did the fan fitting as that was easier!!
Oh well, its gotta be done...........
P.S. The bigger fan and cowling somehow makes the car look as though its got a giant turbine engine fitted!
[IMG] http://[/IMG]
[IMG] [/IMG]
[IMG] [/IMG]
29th July 2014, 14:45
Fan looks almost as powerful as the engine. Just fit a prop blade to that!
29th July 2014, 14:48
When that cuts in it will add 10mph! Make sure that you have the handbrake on at the lights!
29th July 2014, 17:25
Nice work Scottie, its look like your car may hover when she kicks in.
I like the look of the interior ally work, are you coating in a lacquer or leaving as is.
29th July 2014, 18:29
Oxford
WCA
Garyh
Swifty
Thanks for your support fellahs!
Swifty, the alluminium that I have in the car so far, will mostly be covered up by the seats and stuff, the top 2 inches or so above the seat tops will be connaught green, same as the rest of the body.
The inside side panels and central transmission tunnel, (yet to be fitted) will be left bare ally. I have no plans to coat it in anything as I just see future trouble when the lacquer starts peeling off etc. It would look awful, and the lacquer would prove hard to remove to re-do.
Providing I wipe it off now and then, it should not corrode at all.
Perhaps I'll wipe it with WD 40 or some other stuff.
I want it to have its natural sheen.
29th July 2014, 18:55
Ermm, Scottie, is there enough room in front of the radiator and fan for the bonnet to open?
29th July 2014, 19:18
Not as much as there was, but JUST enough!
29th July 2014, 19:34
Later
Hi Alpha, I reckon there were more than you that wondered about the bonnet!
I did check before I fitted, I would have preferred the original gap, but the cooling must come first. It is fairly tight, here are the pics for the disbelievers!
[IMG] [/IMG]
[IMG] [/IMG]
29th July 2014, 19:48
Scottie, I think you should be well proud of that job. Slightly over-engineered (in true jaguar style), how are you controlling it?
29th July 2014, 20:27
I have a brilliant piece of kit I found on the net.
I can dial any temperature from zero to 120 centigrade for the fan to kick in. The beauty of this is the fan can be checked at any time by dialling the temp down to the ambient temp, and it just kicks in.
I have it all on a 25amp fuse as well. ( And a relay)
29th July 2014, 20:30
Scottie - Another great job with the fan.
That 3 piece suite you bought has definitely turned into a serious bargain.
Plus your engine bay really looks like it was developed in the pit lane.
Scottie, I can't help but be staggered at the quality of your build and engineering expertise but those screwdriver hinges just look a bit dodgy ;-)
29th July 2014, 20:35
Nah fatbloke, they're okay!
Thanx Paul!
Landmannnnnnnnnnnn, I just found a pic of the controller:
[IMG] [/IMG]
29th July 2014, 20:45
Seriously Fatbloke, its so bloody fiddly trying to put the bolts in for the bonnet, and that comes on and off more times than a successful whores knickers, so I ruined two good screwdrivers (modified) so they would be a good push fit for the holes!
By the way, it was good to see you at Stoneleigh.
30th July 2014, 07:55
Wow, what a fan, it now looks like you've got 911 power under the bonnet.
Best you fit a pretty strong mesh grille out front or you'll be hoovering up small children when it kicks in at school crossings.
Keep up the good work!
30th July 2014, 08:13
Terrific humour Towed!
Keep that up too, you rarely disappoint me in that area!
31st July 2014, 08:42
THursday
I ordered some polycarbonate (perspex type) sheeting for my side windows, well it arrived yesterday, so today I had planed to get the doors adjusted to the absolute correct position, build a cardboard pattern and cut out the curvy windows.
Out I went bright and early, stripped off the outer packaging, and found I had ordered 4mm twin-wall polycarbonate.
That will teach me to read the description properly next time.......
I immediately imagined myself cruising the Champs-Elysees on a wonderful spring morning in the sunshine, hair blowing in the wind, trying to look cool with poly-fu**ing-carbonate side windows glinting in the sun, and all the French pointing at me..
I don't think so, twin-wall polycarbonate is about as much use for side windows, as a soggy piece of string would be for lock-picking.
Back to the drawing board....................
[IMG] [/IMG]
[IMG] [/IMG]
[IMG] [/IMG]
31st July 2014, 08:56
That must be as irritating as trying to order 2m of black car carpet and realising when it arrives (non-returnable) that you ordered light grey.
At least my garage floor won't be as cold to kneel on this winter
Well, they'd be thermally efficient........
