2nd February 2009, 15:13
Ah, yes - I'd forgotten about that
http://www.madabout-kitcars.com/foru...7&postcount=72
You've sorted out the door capping there - was there any particular diameter pipe the insulation was for? The outside diameter would need to be 50mm, I guess.
And how are you planing on doing the dash surround? Similar idea at the ends to stop it collapsing, I assume, but what about the centre?
Sorry - too many questions!
2nd February 2009, 15:57
Was there any particular diameter pipe the insulation was for? The outside diameter would need to be 50mm, I guess.
I think it was 15mm pipe but I just went to B&Q with a tape measure and picked insulation that was 50mm diameter.
Yes - same at the ends. The insulation is sufficiently strong that it doesn't need support anywhere else. One end of the door capping is cut at 90deg the other is cut at 45deg so it meets (in theory anyway) the dash capping neatly.
I stuck the foam to the thin ply with an impact adhesive for the door capping but I think to make life easier I am going to use double sided carpet tape for the dash capping. I should be doing it sometime this week if you want to wait and see if it works!
8th February 2009, 16:14
the padded foam surround is between 4.2 and 4.5cm all they way round, the end bits are a bit more cubby
28th February 2009, 17:55
Well I am making fairly rapid progress atm (no choice!) I finally got the mobile welder in to weld up the seatbelt support bar that I made - so now I can reassemble the back of the car. The dashboard is complete - although not fitted or tested yet. I wasn't happy with the original one I made (a few scratches and other probs) so I ordered a new blank from Europa and started again. This time the protective covering is staying on until it is all working!
A view of the back showing the piece of ply I bonded to it to increase the strength.
And from the front...
I used ETB instruments in the end (same as GOO) but without the shiny bezels! (Wouldn't have looked right with the machine turned dash). I didn't use the HUGE rev counter as I was worried it would make the dash too weak.
28th February 2009, 19:16
That's looking good and I like the good idea of stiffening the back.
Probably well worth the effort to get a quality finish.
28th February 2009, 19:26
dash
Looking good Robin.I am redoing my dash as i am not happy with first try.Am using whats called Diboard-fibreglass centre sith outer thin aluminium both sides-3mm diameter-used in sign making.(and cheap).! Looking at your dash i wonder if have you used spacer tubes to lower your column, and if so by how much-the depth from top of dash to cut out for column looks deeper than mine with 70mm tubes.
1st March 2009, 16:07
I didn't use the tubes at all so my steering column is mounted the other way up. It means the ign key is more difficult to access but I wasn't keen on the tubes idea.
1st March 2009, 17:59
Me neither, I used an adapter plate - some photos here: http://www.msportster.co.uk/detail.asp?cat=7&offset=108
14th March 2009, 19:17
Car moved under its own power for the first time today. Boy - is the clutch vicious. Cat was impressed as well....
14th March 2009, 19:51
another Sportster obsessed cat
We took the pedal box out the Sportster today to sort the clutch, will be trying the lower hole to get more pedal movement and a Wilwood master. The whole box is getting a work over with thicker metal and triangulation!
14th March 2009, 22:10
Another Sportster complete with SVC plastic bags, just like mine!
And the car looks like its enjoying the warm spring sunshine and just raring to go out for its first trip in the countryside!
My clutch plate was pretty sharp at the beginning, you'll soon get used to it!
You just need about 50 metres of clip on trim to finish it!!
15th March 2009, 16:01
She's looking good basking in the sun. I particularly like the wing mounted indicators. I may have to nick that idea.
Remember, imitation is the sincerest form of flattery. Honest.
Any pics of the dash padding yet?
15th March 2009, 16:23
Hi Robin
Its looking good! On your dash capping, did you just secure the bolts to the ply with epoxy? Is this strong enough? I'm probably going to make my own capping but a bit smaller.
Tim
15th March 2009, 16:51
Originally Posted by timbo
Hi Robin
Tim
Exactly. I made the holes so that the M5 screws were a tight fit and then just put a good blob of araldite under each one. All the araldite needs to do is to stop the screws turning when you bolt it through the dash. At the moment the trim isn't covered so I am leaving it off for the MOT. Once that is out of the way I can start the SVA bits in anger.
15th March 2009, 16:54
On hold at the moment while I do the necessary for the MOT. Once that is out of the way I will return to the trim and SVA bits.
19th March 2009, 07:42
Another day off and another bunch of jobs done yesterday. Rear wings now fitted and lights wired up. Drivers seat fitted - and I can report that the clutch, although heavy, works much better if your backside is not sliding on the floor lol.
I have booked an MOT for Saturday - gulp. Now where's that list of things left to do....
19th March 2009, 07:47
Good luck with the MOT and enjoy your first drive!
19th March 2009, 08:13
Same here, good luck and have fun
8th April 2009, 19:00
Well almost finished the interior at least as far as it needs to go for the SVA. I don't have the Marlin trim kit so I am making it up as I go along. Fitting he carpet is a real b*gger. In the end I made the tunnel carpet from two bits. Mind you I made life difficult for myself as I ran the electrics accross the top of the tunnel so I have had to make the carpet removable. Here are a couple of pics (no time to update the website atm.
Also new tyre for space saver arrived today. It's about 1" smaller than my actual tyres but I think it will do.
8th April 2009, 19:06
Nice, funnily enough I've just come from chopping up bits of cardboard in the garage for a centre console - its looking really good
