13th October 2012, 21:27
Where does the water come from? Spray up from below?
13th October 2012, 21:32
Worse than that - from above!!!
There are drain ways that pass from the gutter around the hood (soft top) down through the sills.
13th October 2012, 21:44
So do you know where the water comes from? Spray up from below or draining down from above somewhere? Would making the drain holes bigger help do you think?
13th October 2012, 21:57
On the sills there are raised marks at the bottom which are indicators for the drain points.
If they are clear there shouldn't be a problem, water will drain out.
14th October 2012, 10:40
Hi
Tytek sorry to correct you but those marks indicate the reinforced
parts of the siderail.
There is one set just behind the front wheels and another just in front
of the rear wheels.
Jack stands and jacks should be placed between them.
THERE SHOULD NEVER BE WATER in THE SILLS.
When You have, your drainage from the Roof (top)
is blocked,causing the water to get over the edge of the catchtank
behind the B-pillar in the sill, and the sill starts to rust.
Check the catchtank and the piping running down for rubbish,leafs etc.
(I even found a pair of sunglasses in there).
Do this regular to prefent your sills to rust.
grtz mx5teo
14th October 2012, 11:07
Originally Posted by mx5teo@planet.nl
Hi
of the rear wheels.
grtz mx5teo
Theo knows a thing or two about the MX5
http://www.youtube.com/watch?v=lw-_n...4&feature=plcp
How's your knee Theo?
14th October 2012, 12:43
Thanks for the correction, more info the better!!!
14th October 2012, 13:23
Tytek, your welcome.
Thanks Chris, I 've trouble with both knees now,but it's getting better
(slowly).Do you have you plans for a mk2 convertiblekit?
regards theo
14th October 2012, 20:25
Great youtube link, thanks Chris. About your sills, all the above is correct, behind the seat belt mount under the hood is a small plastic resepticle with a drain hole about the size of a little finger, this has a tube that comes out under the car inside of the sill, clear this and drill two 8mm holes in your sill front and back but away from the jacking points, any water should now drain out, leave to dry out then buy a waxoyl pump and long extention tube (Halfords sell this). Pump the wax into the sill, I did the inside of the doors as well as there was loads left. Treat the outside rust as normal and you should be ok.
15th October 2012, 08:08
Hey Tonyt
Thanks for the translation.
That is exacly what I mean.
regards mx5teo
15th October 2012, 08:49
Hey Tytek
Well done for tackling the sills yourself . will give you loads of confidence with rest of build. Also for those who know little of MX5"s it shows their worst feature, they rust badly.
15th October 2012, 18:27
I'm looking forward to finally finishing off these sills as the car has been sat for what seems ages. The final cutting and welding the repair section is just a formality. I only have the Saturday to work on the car as I'm off to see the Hairy Bikers on Friday :-D
I promise to finish off the photos in the series too.
20th October 2012, 22:12
Here we go again...
Final clean up of inner sill surface
Dummy fit of new section
Cut down repair section to match the old section
20th October 2012, 22:17
Zinc paint inner sill
Drill holes in repair section ready for plug welds
BEFORE YOU START WELDING, DON'T FORGET TO DISCONNECT YOUR EARTH LEAD ON YOUR BATTERY OR YOU MIGHT FRY YOUR CDI!!!
What a plug weld should look like
Don't forget the arch!!!
Smooth down welds ready for final filling/paint
20th October 2012, 22:27
First layer of filler
Then it's up to you how far you go. As the section is not going to be seen you can leave it as it is.
I've just given the sill a basic fill and sand with a coat of paint to match the colour of the car.
21st October 2012, 15:57
Well done that man! A very tidy job. You will be needing your kit now then.....
21st October 2012, 19:54
I'd love to order it right now but due to numpties at and on ebay my BMW hasn't been sold yet :-(
I'm after £1400 for it so if you want to do a deal I'm up for it :-D
31st October 2012, 14:31
After months of looking, I've eventually nabbed myself a '97 1.8 donor car. All looks pretty solid from above (sills previously repaired) but I'm yet to lift it up to check out the underside & see what work lies ahead.
