Remember on the Pinto that when replacing the head the cylinder head bolt holes in the block must be perfectly clean and dry. If you torque down a bolt in to a hole which contains water or oil then it will torque out when the bolt touches the water/oil surface. You will think that you have torqued the head down correctly but it could be raised on its gasket due to the above problem.
