26th August 2015, 07:56
lovely work, it will be nice to see another colour being used... How does the boot open, are they push buttons?
26th August 2015, 11:33
CarNoob - Congratulations on getting your car painted, the white looks good.
I like the section you added under the number plate, in fact, the whole back end of your car looks very "clean".
26th August 2015, 15:35
yes push button look on page six picture of one in hand. they fasten nicely
28th August 2015, 15:47
Originally Posted by Roadster
That looks great
All that prep and your loss of fingertips was worth it.
Did it go without a hitch?
Painting went ok except for the test area I used a sample can on, so test some spray on some areas first. A friend did a complete re spray on his Lamberetta said it looked fantastic because of all the prep. came back 2 hours later the whole bike had a crackle finish . If anyone else is painting prep then prep again then when ready once more for good measure. Add extra thinners to the final coat. I used a 2 for the high build and1.4 nozzle for the finish next time final coat would be with 1.8 nozzle
18th September 2015, 15:36
trial fit for the dash side panel, still work to do on the removable carpet.
18th September 2015, 16:54
That all looks very nice.
29th September 2015, 14:46
Car now has lights. had same problem as you Paul, holes for indicator screws too close to the centre hole. Slipped with drill and chipped paint just above the light, small job but annoying.
29th September 2015, 17:58
Sorry to hear you also had indicator fixing problems.
But getting the headlights fitted really does make a big difference.
17th October 2015, 09:40
Maserati badge
<a href="http://s1354.photobucket.com/user/JPB007/media/Mobile%20Uploads/20151017_093734_zpsof5esky6.jpg.html"
17th October 2015, 09:41
19th October 2015, 13:54
Nice work on the badge.
Is it to the same scale as your cardboard mock up?
19th October 2015, 17:26
Yes size is about the same. Made a rubber mould today. I am going to cast in a two part resin plastic that is very strong, I may make another in aluminum. But first need to make a small foundry.
19th October 2015, 18:53
Why dont you buy some aluminium powder to go in the resin that way if buffs up and looks very metallic
http://www.easycomposites.co.uk/#!/r...er-powder.html
19th October 2015, 19:12
I have not see that before thanks I will give a try
27th October 2015, 14:45
side vent
I have fitted led indicators inside and a mirror to help reflect the light
27th October 2015, 14:49
Very well executed, looks standard.
27th October 2015, 14:51
27th October 2015, 14:56
Do you have one of the back end?, i can just see the diffuser...
27th October 2015, 15:02
Very nicely finished lots of great details
Any plans to sell tridents?
27th October 2015, 17:04
Looking very good.
Is there much left to do before you can take it for an MOT?
