Old 19th March 2014, 19:02
Default Headlight covers
Hi guys
Has anybody else fitted the covers WITHOUT cracking them???
Not sure if I tightened the screws too much or the fact that I fitted them with chrome headlight rims fitted .
Ideas please to prevent this happening again .
Grrrrrrrrr
Old 19th March 2014, 21:03
fatbloke fatbloke is offline
I haven't fitted mine yet but I plan to bolt them through rather than screwing.
Old 20th March 2014, 08:00
Both mine went on fine. Then I knelt on one and cracked it. Removed the pair and cracked the other.
I reckon some kind of rubber washer/grommet is the answer.
Old 20th March 2014, 11:36
Having fitted screens to various motorcycles over the years they use either expanding rubber mounts or plastic washers to avoid cracking the plastic.
Old 20th March 2014, 22:26
seanick's Avatar
seanick seanick is offline
They don't need to be too tight.
If the perspex has dipped even slightly under the screw head it's too tight.
If you need a closer fit add more screws.
Have good clearance holes for the screws because perspex enjoys thermal expansion.
Use pan heads, not csk.
N
