IVA chassis number for strangers
hi all,
im trying to sort a problem, but i cannot find a clear answer.
im not english, and i also some problems for understand some details.
my kitcar was made at SVA times, now with IVA there are some changes about the chassis number.
i found a post about MEV Exocet, seems MEV weld a plate to chassis and give a 'cosmetic plate' to rivet to chassis.
this is pretty clear, and i want to do the same.
my question is, where i can weld the plate?
IVA manual, at section 18.6 say "The Stamped in VIN must be placed in a clearly visible and accessible position". not very clear. visible can be 'visible from outside', or visibile if you get into the car, or visible if you open the bonnet.
where the numner is welded/stamped in your chassis?
under the bonnet is acceptable?
and.. where is rivetted your 'cosmetic plate'?
thank you very much!
David
