26th August 2011, 08:02
sva testing nightmare,
hey guy's
first time on the forum, actually posting on behalf of a friend who has just taken a beating over an sva test, app 5 full pages of negative comments,
who or were is the best place to look for answers to what has been given or should i pop it up on here for help??
regards jake
26th August 2011, 10:09
I'm sure if you posted up the fail points from the IVA test, we'd all be able to help out with some advice. Without it it's difficult to see what the problems are.
26th August 2011, 10:18
i will borrow the paper work and make a note,
i know for sure one was they tyres are under rated for the speed rating
26th August 2011, 10:50
Well that one's a simple fix - the inspector will check the speed rating of the Tyre against what the claimed top speed of the car is - your mate will have put that on his IVA test application.
If it's too low for the claimed top speed, he'll either have to change the tyres, or re-state the top speed. How he goes about that, I don't know, as I didn't have an issue with that.
You can alway take a look at the IVA manual as well, as it will have all the expected standards in it.
http://www.transportoffice.gov.uk/cr...enger-Cars.pdf
Tyres are in section 46.
26th August 2011, 11:06
The main point from the test is that there are too many sharp edges on the car… but his question is “what are you supposed to do about the lock nuts on the track rod ends” as they were deemed a sharp edge. On the failure notice it says: All hard parts contactable with a 100mm sphere, which form an external surface or protrude 5mm or more from the external surface must have a radius of curvature of at least 2.5mm
Additional information:
1. N.s and o.s headlamp bkts 2. N.S and o.s suspension parts, 3. Track rod end lock nuts, 4. Exhaust shields, 5. Bonnet catches, 6. Windshields, 7. Bonnet ends, 8. Exhaust bkts, 9. Mud wings 10. Wing mirrors.
Wheel arches must be ‘turned inwards’ or have a radius of curvature of at least 2.5mm
The tyres section says:
Each tyre must have the adequate speed capability (speed rating) for the maximum design speed of the vehicle
S rated tyres 112mph, declared road speed 125.
thanks guys
26th August 2011, 12:09
SVA nut covers - http://www.cbsonline.co.uk/category/..._Covers,b.html used these all over the place on the front suspension.
As for hard edges, I used rubber everywhere - glued down so it's not "temporary" http://www.cbsonline.co.uk/category/Trim,b.html
For the exhaust I made a spacer bar so the wedge they use to measure impact areas avoided sharp stuff. Otherwise, again rubber trim is your friend.
Can he borrow another set of wheels with higher rated tyres? I'm not sure if you can amend the paper work to reduce the top speed of the car.
My SVA issues and fixes are documented here: http://www.msportster.co.uk/sva-day/
EDIT: GOO posted quicker
30th August 2011, 14:43
thanks guy's
all passed on perfect
thank you very much
