Old 11th March 2012, 20:23
Bobnic Bobnic is offline
Bobnic is on a distinguished road
Default Help with clutch plumbing please
It's now time to get the clutch plumbed in, was after a bit of advice please. Where can I get the fittings and hoses from for my E36 M3?? As me and clutches are not very well known to each other and I could spend a lot of time (and money) ordering and trying the wrong stuff!! I suspect the hoses will need to be custom made, or can I use original OEM Beemer ones or some other manufacturers OTC hoses?
Thanks as always in advance for your pearls!
Rob
Old 11th March 2012, 20:51
morris's Avatar
morris morris is offline
I made some of may own hoses by using a local supplier, torques.co.uk. He's got a wealth of different types of adapters and fittings to sort you out. Works out about £20 per 1m hose. You'll probably find the clutch master and slave use M10 fittings. I went for banjo fittings as they're that much easier to work with in tight places. I think that you'll find buying genuine BMW parts in the instance is a waste of money as they'll be designed length wise to go through the bulk heads in specific places which may not be where you need them to in the sportster
Old 12th March 2012, 07:43
timbo timbo is offline
I used a Marlin-supplied clutch master cylinder and hose and found these notes from my build diary:
Clutch hose had both ends metric (M10), but clutch master cylinder is 3/8 UNF so ordered a new cable from furore cars.
And their hose did the job no probs. I agree with Ian that you need to get them made to the right length, unless you can do it yourself. Fortunately not too expensive, relatively of course
Old 12th March 2012, 07:55
MartinClan's Avatar
As I recall, I used the standard BMW flexible hose from the slave to a convinient mounting point on the bulkhead and then made up the rest in kunifer using standard brake line type fittings.
Old 14th March 2012, 18:54
Thanks guys. Going to visit a local hydraulics firm Friday, see if they can make the hoses we need.
Rob
Old 14th March 2012, 20:05
Patrick's Avatar
Patrick Patrick is online now
I used standard BMW slave cylinder a new original BMW rubber pipe to the bulk head. From there I used a copper pipe up and under the battery tray into the car up to the master cylinder. Initially I used the BMW master cylinder but the pedal box proves to be made out of cheese so re-enforced it and I've completely re-done it with a willwood master cylinder and cage.
You can see the copper pipe in this image:
Through into the master cylinder:
Slave cylinder with pipe coming off it:
Here with the pipe / gearbox mounted:
There's some pics of the pedal box mods here: http://www.msportster.co.uk/rolling-...llery/page-44/
