Old 2nd April 2005, 07:52
Default T16 Oil Flow/Direction
Ok people,
On the T16 installs we have to fit a blanking plate where the Oil Filter is. The Oil Filter is re-located on a remote head. Good.
But what is the oil flow/direction from the two pipes at the blanking plate?
Could someone (hi Trev!) describe the oil pipes and connections they have on their install please?
Thanks,
MarlinTurbo
Old 5th April 2005, 12:12
Default Why ever?
Would you think that I would reply.
I dont know..... Right what I have done is moved the cooler to the right hand side of the engine in front of the offside rear wheel.
The logic being to actually give it some air flow, which was missing on the 420.
As for the rest, i'll email a couple of shots that clearly show the 'run'.
Nuts, no internet at home till friday can you wait or shall I just bring em into the office?
Trev
Old 5th April 2005, 18:22
Hi mate,
Moving the cooler is on my list too...same place as you've stated...
For now, I thought I had a problem with Oil Pressure so wanted to check the 'run'...I'm getting 60+ psi at start up...but this is quite normal...!
Still I would like to compare notes with you matey!
MarlinTurbo
