Old 27th July 2006, 17:07
BIG_Fella's Avatar
BIG_Fella BIG_Fella is offline
BIG_Fella is on a distinguished road
Default woohooo got me drive shafts
After much weighting i have finaly got me drive shafts for the type-r kit
Lets hope they fit
Jerry
Old 27th July 2006, 19:08
craig's Avatar
craig craig is offline
Hi Jerry, Can I ask how much Marlin charged you for the drive shafts as I have them to buy soon and also from a previous post is there any chance you could list the items needed from the civic for me as I got the impression that there is more than I thought?
Ps I contacted Marlin about the civic cd you mentioned and only thing Terry knew about and sent me was a Rover manual! Is it a separate cd to the build pictures cd?
Many thanks
Craig
Old 28th July 2006, 09:46
BIG_Fella's Avatar
Craig
Price of drive shafts £????? i am weighting for them to sort the price out terrys thinks they will be about £170 each
As for the civic disc you will need to speck to mark!! IF you get no joy from him i can probly do a copy and send it
As to the civic bits that are required you will need
Engine
Gearbox
Starter motor
Altinator
water pump
Half shaft
inboard cv's
ECU
Lamda Probs 2 off Try and get the complete wiring for they
Engine wiring loom up to ecu
The third plug that come's out of the ECU and go's to the internal wiring system
A non air con drive belt
I think that is all of it
Jerry
Old 28th July 2006, 16:55
craig's Avatar
Cheers Jerry!
I think that the third plug going to the rest of the wiring loom is a problem for me as I don't have this and the lamda sensors I don't really know anything about these or where they are located....think it's something to do with exhaust!!
The rest of the items came with the engine!
Craig
Old 28th July 2006, 17:02
BIG_Fella's Avatar
The lamda probs are located either side of the cat
I dont have the third plug either but a mate has made me one by soldering wires to the ecu and putting a muiti pin plug on the end of them
you will still need to get a shorter belt for the water pump unless you are going to fit the air con witch would be bloody hard to do
Old 28th July 2006, 17:17
craig's Avatar
No I have no intention of fitting air con build will take long enough as it is, I had presumed that the engine I have was not fitted with air con!
I take it that the belt is available from Honda for type r engine without
air con? Do I need to take anything of the engine then, or is it just that the belt on the engine was connected to pump before removal?
With the lamda sensors I take it that a couple of inches of wire from each one will be enough?
Regards
Craig
