Old 29th November 2010, 11:07
MikeMF MikeMF is offline
MikeMF is on a distinguished road
Default Sierra Based
Hi
We have a Sierra based Marlin car with drum rear brakes, dose anybody know how to change from drum rear brakes to disks
Many thanks
http://classickitcargroup.zxq.net/index.html
Old 29th November 2010, 19:26
Simon's Avatar
Simon Simon is offline
Simon is on a distinguished road
Hi Mike,
I think there is quite a bit more to this than first appears...!
As well as needing the discs, pads, calipers & caliper brackets I think you may also need different hubs/arms, handbrake cable as well as the bolt on driveshafts (and you may therefore also need the wider 7.5" diff)....
I changed my Marlin Cabrio over from rear drums to discs but ended up swapping over the complete axle (as it's probably the easiest / cheapest way):
http://www.flickr.com/photos/marlin_...7594349599658/
Might be worth seeing if someone sells a conversion kit but, on the other hand, complete disc brake Sierra rear axles go quite cheaply on Ebay.
Hope this helps
Simon
Old 30th November 2010, 11:00
Thanks Simon
Great photo's and nice garage, as you say a complete axle may be the way to go.
I can then do a refeb on the axle.
Old 29th September 2011, 07:46
mashtun mashtun is offline
mashtun is on a distinguished road
Hi Simon,
I'm resurrecting this thread as changing from drums to discs was something I always had in mind for my Cabrio rebuild.
Did you replace swap out a 7" diff for a 7.5" one? Am I right in thinking the casing itself is physically bigger i.e. it's not just the internals that are a different size? I've seen mention that the width of the upper mounting 'tube' differs. Did you have to change the point where the Marlin diff carrier brackets mount to the chassis? Or change the brackets themselves, perhaps?
I gather it's possible to fit the Lobro flanges to a 7" diff previously used with Tripode driveshafts so that's an option for me - but it seems like a half-way house sort of compromise really.
How about the trailing arms - were you able to use the pair that came with the drum setup or did you have to replace them? I've read that the hole for the bearing/hub assembly is larger on arms used in disc setups.
Thanks,
Mark.
Old 29th September 2011, 17:44
Simon's Avatar
Hi Mark,
Yes I swapped the complete diff over and, like you say, the casing is physically bigger on the 7.5" unit.
The main difference is in the attachment of the front diff mountings which are further part on the 7.5" diff (presumably by 1/2" ?!). However you don't need to change the Marlin brackets - the mounting holes on the chassis are just further apart. My chassis already had holes drilled for both 7" & 7.5" diffs - so yours may do too.
I'm not sure about the differences in trailing arms - I just used the ones that came with the disc brake axle.
Its actually quite a simple swap if you change the complete axle over (I expect you'll only run in to trouble if you start mixing and matching components).
Good luck & I'm happy to try and answer any other questions.
Simon
Old 29th September 2011, 19:45
Hi Simon,
thanks for the info and good wishes. My chassis has only one set of holes. If the larger casing's 1/2" wider then that's only 1/4" on either side - presumably the pairs of holes on your chassis are either very close together or slots rather than individual holes?
That apart I think you're right - it seems a simple enough change.
Mark.
Old 29th September 2011, 21:36
Simon's Avatar
Two individual holes but quite close together as the 1/2" offset is all to one side (passenger side if I recall correctly).
Simon
Old 30th September 2011, 06:23
Ah, I see. Thanks, Simon.
Mark.
Old 30th September 2011, 10:11
echok4le echok4le is offline
echok4le is on a distinguished road
i love it..can i look at it?
rack mountable pdu
Old 9th October 2011, 13:43
kentl3vy kentl3vy is offline
kentl3vy is on a distinguished road
ciao to all........
have a nice time here...
ecommerce fulfillment solution
Old 14th October 2011, 09:06
redratbike's Avatar
i think an xr4x4 had an lsd but not sure if this is 7 or 7.5
