Old 16th November 2017, 14:58
Default chassis
Hi all
I've checked the measurement at the back of the deon and have 1480mm disc face to disc face. Giving a rear track assuming the deon wheel offset is -8 per side of 1464mm. Again wider than the 246 by 34mm and again this is possible to reduce on the bottom pair of wishbones but later spec deon's had fixed upper wishbones so narrowing of the chassis is needed.
ian
Last edited by thecarbuilder246; 16th November 2017 at 15:14.. Reason: missed a bit off
Old 17th November 2017, 00:08
That is very interesting Ian! Perhaps the later Deon chassis that you have is wider to cope with the Ford engine? I guess that narrowing the track but keeping the same driveshafts would need checking to see that the shafts still had enough travel, lengthwise, so they don't bind. Given that the Deon body shell was originally moulded from a 206 Dino the 206 tracks are what you want to replicate? To my eyes the way the wheel/tyre combo fills the arch on the 246 looks better on the 246 than the 206.
The Ferrari Dino 206 was:
track front: 1425mm. (246GT is 1425)
track rear: 1400mm. (246GT is 1430)
here are a few images - the 206 was originally specced with narrower 185 tyres as well as having a narrower track in the rear:
