8th May 2013, 16:13
Rear end painting.
8th May 2013, 16:21
Progress
8th May 2013, 18:20
Weight reduction.
Removed the items on the left replaced with the item on the right, it all helps.
8th May 2013, 18:40
Little work required still.
8th May 2013, 20:04
YES I know sanding till the doctor comes
looks good
How do the long hinges fit
10th May 2013, 19:10
Hinges are fine now, thanks your build looks very good after the sanding, like the the saying sanding untill the doctor comes, mad me chuckle don't think it translated well as thats quite extreame but I know what you wanted to say.
11th May 2013, 21:41
A bit of progress tonight before it started to rain, new hinges bolted down with big flat washers and locking washers, more fiddely than Mr Fiddle, playing the fiddle on Fiddler on the Roof (kept dropping the washers and had to shake the boot to get them out of the double skin). Check straps fitted amd I have decided to bin the lifting rams and will have something more simple instead, mayby even a handle.
12th May 2013, 10:42
Rain stopped play last night still need to sand the lid to get the shut right, now the sun is shining but the GP starts in half and hour, have to tear myself away to watch it and continue later.
12th May 2013, 19:08
My penance for watching two Fiats get on the podium, more rain, just started filling around the hinges.
12th May 2013, 19:30
Does anyone know what these are called? As a few have broken when I took the carpet up and I need to order some more.
Reason: Wrong picture.
12th May 2013, 19:59
Send me your adress and il post you the 1s ive just removed from mine, i wont be needing them.
12th May 2013, 20:05
Hay, thanks its A D Thomas, 1 Links Road, Deal, Kent CT14 6QF, what do you plan to do about wheels?
12th May 2013, 20:09
No problem mate, im going to have a look at some spoked wheels possibly from an old mg or somthing of the sort.
12th May 2013, 20:15
Been looking at somthing like these....
13th May 2013, 15:09
The wheels look good you may need split adapters, I got mine from the US, to fit original wheels, went from 4x100 PCD to 5x108, the kits arches are wide enough for this even had to use spacers on the rear.
13th May 2013, 15:43
Yeah these are a 5 stud, my pal has an engineering company so he'l be doing them for me, he done them for my last kit car when I had fitted mercedes alloys to an mr2.
13th May 2013, 20:17
still not sure about the front corner.
13th May 2013, 20:25
13th May 2013, 20:30
13th May 2013, 20:35
Fuck it I'll live with it.
