Old 18th March 2011, 19:39
JONORacing's Avatar
JONORacing JONORacing is offline
JONORacing is on a distinguished road
Question IVA/MOT Headlight Test
Hello,
I'm after a little help if possible on what seems a small and easy subject.
I was wondering two things really;
1) What is the minimum hieght that the headlights must be from the ground at MOT & IVA?
2) Where do they take the measurment from, i.e the lowest point of the headlamp to the ground or is it the centre of the beam when emitted on a wall a set distance away.
Any help would be much appreciated,
Cheers Jono
www.JONORacing.co.uk
Old 20th March 2011, 08:09
limpabit's Avatar
limpabit limpabit is offline
Going by this manual, http://www.completekitcar.co.uk/Reso...anual%20v4.pdf, between min 500- max 1200mm.
I would say that was from the ground.
Old 20th March 2011, 17:12
JONORacing's Avatar
Hi John,
Thanks for the reply, I have managed to confirm that the min height is 500mm.
The difficult bit is trying to determine the distance between the wall and the car so I can adjust them up to the correct hieght, whilst still being within the correct angles. If I go with the bottom on the headlamp unit then I loose atleast 50mm
