7th February 2013, 20:04
7th February 2013, 20:29
wow you got it
Thumbs up, looks damn good
Good luck for the rest
7th February 2013, 20:38
Nice one! If you don't mind telling what did the paint job cost?
7th February 2013, 21:50
Top Dallah!
7th February 2013, 22:16
Well done Grahame. It looks very shiney! Must be one of the quickest start to finish builds of a 250. Was it sprayed in a booth then baked?
8th February 2013, 17:53
thanks redrarbike I managed to get the primmer ics on but forgot how
8th February 2013, 21:36
No worries...looking good
9th February 2013, 17:27
Hi all week 7 thanks for the encouarging coments, Im having a problem with the side ,tail, number plate & fog lights ,Ive checked the fuses & they seem to be ok.so I think it might be a relay but where is the light relay?, has anyone put the rear sceen in there self,I dont know whether to risk it,
9th February 2013, 17:33
Hi Hammy & Nick the paint was done in a booth I dont know if it was backed,he chareged me £400 for the top coat,I have to take it back later for a flat back & polish
9th February 2013, 18:08
Hi Grayone,
Do you have 12V (positive) to the bulbs?
Best measured against a good ground, ground not measured in the lamp socket
Then measure from the battery + to, the - ground of the socket.
Somewhere I have a wiring diagram
I'm looking for him
9th February 2013, 19:00
Not bad considering the cost of paint, good call on the diagram being male, it would be as its a blokes thing, if we used gender in English, we only use one that I know of and its "she" for a boat or a ship, every thing else in English is neutral. still the english is better than my German, so hats off. (or my Fench or Czech).
9th February 2013, 19:15
Do not ask me about grammar
I'm working on it
9th February 2013, 19:58
The car looks great Grahame Can't wait to see it with the new wheels installed.
The light problems will be an earth fault, almost certain of that. Check for any loose connections, all the lights share a common earth as far as I know.
You will need 2 people to put in the rear window. Feed a piece of strong string around the inner channel of the rubber seal (with it in place on the glass) overlap the string at the base of the window, put the loose ends of string inside the car, then push the lip of the rubber over the bottom edge of the window opening, with your helper pushing down on the glass from the outside pull then string slowly out from the rubber causing it to pull the rubber over the edge of the window opening. Take your time and it will fall into place, once in you can seal under the rubber with clear silicone.
10th February 2013, 16:24
Thanks Chris it is looking good now Ive fitted all the mesh today put the new wheels on at last I'll try to get some photos tomorrow ,I have fitted separate earths to all of the lights I'll have to check them again failling that I'll go to an auto electrician.
10th February 2013, 16:27
Hi Heinrich I dont have a meter to test it with
10th February 2013, 17:28
Hi greyone, all you guys are an inspiration! I have no mechanical ability at all, but love beautiful cars and the mx250 certainly fits the bill. Thankfully Chris has taken on board the task of getting my dream car on the road, looking forward to seeing all your cars at Stoneleigh
10th February 2013, 18:01
Looking forward to those photo's, fingers crossed on the lights.
10th February 2013, 18:30
Hi Ken
Yes, it would be great to see an MX250 line up at Stoneleigh, including your "Black Beauty"
10th February 2013, 20:46
When's Stoneleigh this year?
