Old 30th August 2014, 17:24
blueface blueface is offline
blueface is on a distinguished road
Have a look at this which should help. Every light will have its own colour plus a ground (usually brown but it's black in the z3 lighting pod). You must extend each cable to the new lights plus a ground cable but as long as the black ground is run to each light (in series) it'll make it work.
You must have both rear sockets plugged in as there's a loop in the right hand which feeds the brake light on the left.
There are only side light and brake light at the rear. I'm adding low under mounted fog light and no reversing light. Fitting reversing sensors instead!
Old 30th August 2014, 17:51
Andyboy Cambridge Andyboy Cambridge is offline
Andyboy Cambridge is on a distinguished road
Thanks again!! So it's as simple as chopping wires adding extentions to new and adding an additional ground ���� So am I not right in thinking that on most cobras there is and indicator light top, underneath that is dual side and brake light ?? then the dredded must have of a fog like like u say should be hiden away at the bottem��
Old 30th August 2014, 22:25
That sounds right. Indicator, side/brake light and then separate fog and that's you sorted.
Front is more of the same. Plug in the bulbs again. Work out which is dip and full beam and then extend to new lights (which is a bit more awkward as you have to go back to the bonnet hinge and forwards again up the bonnet to the new lights. I patched into the main loom just back from the left hand lights to save running cable from the right hand and across the front before running backwards. If I recall correctly the right hand fronts were blue/white and blue/yellow.
Old 31st August 2014, 09:43
Sorry for all the the questions but is there a way to incorporate the brake and side lights into the one light I bought land rover lights which has the one bulb... Is it a case of wiring the to wore to the same bulb? :-s
Old 31st August 2014, 13:32
Your brake/side light - the bulb should be a double filament bulb so you'll have two wires plus a ground connection to make to it. There should be separate connectors on the bulb for all three wires.
Old 1st September 2014, 15:34
Thanks for your help blue face :-)
Old 1st September 2014, 18:11
IanA's Avatar
IanA IanA is offline
And wire it so that the brighter filament (usually 21w) is the brake light. The dimmer filament (usually 5 or 6w) is the side light.
Once you've got them working... you can get LED bulbs as direct replacements if you want brighter lights.
If you fit LED bulbs in your indicators, you will have to fit ballast resistors in parallel with them to slow down the flash rate. It's because they use less power that it affects the flasher relay and speeds up the flash rate, the resistors compensate for that. Been there, done it.
Old 14th September 2014, 20:25
how are you guys getting on?? id love to see some pictures?
Old 15th September 2014, 13:31
Old 15th September 2014, 19:49
Very Impressive !! What did you use for your side vents?? And ne idea if it's legal to not have the side indicator??
Old 15th September 2014, 20:21
Side vents came from an eBay seller of Dax cobra parts. Search for cobra side vents and it should turn up something hopefully. Not cheap though at about 90 quid.
I have a side indicator there. I think it is a requirement but not 100% sure.
Old 15th September 2014, 20:48
y cymro's Avatar
y cymro y cymro is offline
That's a lovely colour. Are you tempted to add a Kobra stripe?
Old 15th September 2014, 21:16
Extremely tempted but just lost heart in painting anything at the minute and not sure about using vinyl. Would have liked gun metal grey stripes to match the wheels.
Old 15th September 2014, 21:37
redratbike's Avatar
http://www.ebay.co.uk/itm/Dax-AC-Cob...item20dc47d27f
Old 15th September 2014, 21:41
redratbike's Avatar
Bit more fixing required for this onehttp://www.ebay.co.uk/itm/NEW-Pilgri...item417b14cdf9
Old 15th September 2014, 21:46
redratbike's Avatar
Or spray these body colour or contrasting colourhttp://www.carbuildersolutions.com/u...de-vents-black
Old 15th September 2014, 21:47
redratbike's Avatar
Yeah yeah I know it says stick on but mounted behind a cut out I was thinking
Old 15th September 2014, 21:48
redratbike's Avatar
Has anybody fitted a full set of chrome work yet to one of these?
Old 15th September 2014, 21:53
Thats the one I have! They came with a couple of threaded rods which I had to cut shorter and fibreglassed onto the inside of the panel. Good fit for the recess.
Old 15th September 2014, 22:13
redratbike's Avatar
Another one on ebay
http://www.ebay.co.uk/itm/COBRA-KIT-...33829966&rt=nc
