11th July 2012, 12:19
Using V5 from a scrapped or SORN car
Hi Guys,
Hopefully a quick question.
I am going down the route of age related plate for my Countach.
Now I have the opportunity of purchasing one of two renault gearboxes/transaxles.
One is from an already scrapped car - can this still be used?
The other one, which is SORN, but he cannot find the V5C for it at the mo.
What do you think I should do, go for the one which is already scrapped or is this not allowed?
Steve
12th July 2012, 12:29
I suggest you look at http://webarchive.nationalarchives.g...le/DG_10014246
Note that your car will be a "kit conversion" and you need to be able to prove that 2 major items came from one donor car to get an age related plate.
12th July 2012, 20:39
Thanks Chris,
I understand that I need two major components, gearbox and axle, for me.
My question then is if I buy a car that is SORN, do I have to reg it in my name and SORN it again till I reg the new car?
13th July 2012, 06:52
I'm not 100% sure on that one, but in theory if you buy the car you should become the registered keeper. Then you may have to re-sorn it.
After that you need to remove what you need, and I suggest you take loads of photos to provide evidence should there be any query. If possible photograph any visible serial numbers to prove continuity. After that you can take off more bits and flog them on ebay. Make a copy of the log book and then get the remains scrapped.
You don't have to have the remains of the car when attempting to register the new one. For me there was a gap of 7 years between scrapping the Seirra and registering the Marlin.
13th July 2012, 14:04
Kit Car Dreamer
Dvla are hotting up on cars that are not properly registered, when you go to register it you will either be asked to have your car examined when the vehicle will be checked to ensure it matches what the log book states, if not it will be taken off the road and you will have to IVA it or be told that because its heavily modified you will need to IVA it
any registration you may have will be invalid if you have to IVA it, and you might end up with a Q plate
You can not use an identity that has been scrapped and reported to DVLA as scrapped, if you use the identity of a car thats on SORN , you will once you re register it have to have it examined and if your Vin does not match the V5 its IVA route
This has happened because of people buying up old kit cars , scrapping them and using the registration instead of putting their car in for Iva
13th July 2012, 14:10
If you are building a car from a kit and not declaring it as re-bodied (like the Sammio builds) then the only correct order is:
1. Build it
2. IVA it
3. Apply for new registration from DVLA. Then argue with DLVA if it should be Q, Age related, or current registration.
What you can't do unless you want to get into deep doo-doo is to use an old V5.
13th July 2012, 19:14
Sorry, I wasn't clear, I know I have to IVA as I have a new chassis and body, I am trying to claim the use of the gearbox and transaxle from a donor to get enough points to use the donors reg and have it re reg'ed.
Luckily the Renault has a transaxle
28th July 2012, 19:04
If it is SORN and you register as it's owner you do need to sorn it yourself (no big deal anyway) or you might have problems with the Dvla when you do tax it. I did with a Landrover I rebuilt. Eventually I got away unscathed.
