Old 6th June 2012, 19:05
Unhappy Mk1/Mk2 heads
Just wondering if i can put a Mk2 head on a Mk1 block? This may have been done already as my Vitesse is a 71'. I am only asking as i have made a bit of a mistake... I was having trouble taking a manifold bolt out, above it was a square sided bolt (a drain plug for water). Basically i ended up rounding off the bolt , so ended up cutting off the main part that was left so, i drilled the centre out and used one of those extractors I thought at some point it will shift especially with a pipe on the end of spanner well , it did come free along with the corner of the head
oh sugar...
Old 6th June 2012, 19:25
Haven't a clue if the heads are interchangeable I'm afraid. Could be an excuse to fit a shiny, reconditioned unleaded head though...
http://www.ebay.co.uk/itm/Triumph-Vi...ht_1139wt_1185
Old 7th June 2012, 06:37
phil9 phil9 is offline
noit will not fit
