7th December 2016, 12:51
Now THAT is like a shooting brake, rather than a hearse.
7th December 2016, 16:28
Should be quite easy to do too : The car would retain the Corvette targa top. AeroWagen bodywork replaces the original Corvette hatch utilizing the OEM seal, hinge and latch mechanisms
I wonder what other cars could be modified in this way?
Remove the old hatch and add the new body over the remaining hole...
7th December 2016, 18:04
Maybe something like a Toyota celica mk7. Got a hatch. ?
7th December 2016, 19:16
Mitsubishi GTO Twin Turbo. Very cheap to buy and they don't tend to rust. 4WD and 4 wheel steering and a shape that already has a Ferrarish shape.
Awesome performance for vey little money.
7th December 2016, 19:43
Ferrari testarossa ? Like the 4x4 part.
8th December 2016, 09:26
I have always had a softspot for the last of the RX7s
rx7 Wagon by WCA!, on Flickr
8th December 2016, 09:30
I think I prefer the Jag with the Moggy minor bolt on!
8th December 2016, 10:45
My photoshop (MS Paint) skill might need a little tweaking to make it look pretty :-)
8th December 2016, 11:25
aweesome cars... horrendously complicated electrnics and they are at "that age"... :S
What about a Supra?
8th December 2016, 18:13
So what could you use as a base for one of these?
8th December 2016, 18:28
What about a Supra?
The one's that are left generally are pretty good. Main problems are hardening of valve stem oil seals, turbo's burning oil and gearbox synchro's going.
Ive had a lot of high performance cars over the years but the 3000GT (UK version of GTO but higher spec and bigger turbos) is something else, heavy car but once you wind it up
10th December 2016, 14:02
Not wanting to step on toes but has anyone tried using a rover p6 as a donor. The wings front and back come off and it has a v8 modor. Maybe a Ferrari coupe could be made or indeed a muscle car with slightly higher haunches at the back. Make it a 3 door etc
11th December 2016, 18:13
[QUOTE=zagmad;84736]Not wanting to step on toes but has anyone tried using a rover p6 as a donor. The wings front and back come off and it has a v8 modor. Maybe a Ferrari coupe could be made or indeed a muscle car with slightly higher haunches at the back. Make it a 3 door etc[/QUOTE
With a pretty expensive de-dion rear end I seem to remember
14th January 2017, 14:07
Here's one for Chris
DB5
http://www.ebay.co.uk/itm/SEAN-CONNE...oAAOSwjDZYeOE7
If you made it into a Volant I'm sure with a bit of jiggery pokery you could get it to sit on a standard Scimitar chassis.
A lot more practacle than an Auburn!
14th January 2017, 14:21
Hmm - Alarm bells here? Listed for a friend - yeah of course. On a shortened Scimitar chassis with V5 - so not of note because it will need an IVA.
Good try..
14th January 2017, 14:27
I think there will be little demand out there for the Auburn. Without a chassis to bolt it to the job is 10 fold more difficult to build. All very well saying it will simply "bolt on" to such and such chassis but it simply won't be that easy!
7th February 2017, 19:34
7th February 2017, 19:39
That's yummy, good taste fatbloke.
7th February 2017, 19:51
Its one of those cars you need to drop the suspension to the ground and put wide wheels on first then start the build. Quite an angular windscreen
8th February 2017, 08:20
Originally Posted by fatbloke
Easy to create, theres an MR2 based dino shell, front lights need modifying
