7th October 2012, 12:31
Tools Required for Tribute Build
Hi,
I was wondering if anyone would be able to list all of the tools required to undertake the Tribute build.
I have nothing in the way of mechanics tools although I do have a hammer and chisel at the ready!
Any advice would be most appreciated as I am expecting that this investment needs to be taken into consideration.
Many thanks,
Brian
7th October 2012, 18:59
Mmm, well how about...
An average socket set
An average ring spanner set
An average screw driver set
I think you need those just to get through life in general if you own a house/car/bike or boat
A jigsaw for trimming window surrounds an gtp panels, but you could use a hacksaw or pad saw.An electric drill for er hole drilling
Set of bits for the above. Again a usual household tool.
Trolley jack and a pair of axle stands sanding is handy, but not nescercery. If you are into cars you probably have these.
An electric sander is nice, but not nessercery. You get a better finish with long boards and hand sanding wet.
Volt meter
I reckon most of that would nit cost a lot if sourced at a car boot. New maybe £150?
This list is not exhaustive, I just cannot think of anything else!
7th October 2012, 19:51
Volt meter
Nick, you have beaten me to it again! Your list is only missing the pop-rivet gun and electrical fittings crimper.
7th October 2012, 20:18
I'm sorry. If I spent as much time working on the car as I did on this forum my build would be finished by now......te he.
Had a great time at Goodwood today, with two sessions on the go kart's with some mates so they did a grid start for us.....chaos!
Went in the Morris and the Burlington, with family co-drivers.
Finished the final details on the Burlington like rear mudguards and some front suspension covers, but just have to reshape the exhaust where it touches then its sort of finished for now. Only finished those bits friday. Then will start on my 250 this week....shock horror, even though I am still waiting for my wheels.
8th October 2012, 15:13
You've missed out an angle grinder with 1mm cutting discs and flap-wheel sanding discs.
I'd probably say that on my Sammio build the angle grinder is the power tool i used the most for cutting / restyling / grinding / sanding / shaping etc. and while the kits are different the "type" of build is similar so i'd imagine the type of jobs are similar?
The 1mm cutting discs go through just about anything with amazing ease and saved me SO much time and effort! And those flapwheel discs were brilliant for shaping glass fibre, as well as cleaning up metal and were more friendly than grinding discs when necessary!
8th October 2012, 18:22
I agree with a grinder (grindette, 4") being handy (I have four, to save changing from cutting to grinding to sanding etc) and you could sub one for a jigsaw as it has more uses, but, it will not cut fair curves very well, so for trimming GRP I prefer a jigsaw with a metal cutting blade.
Flap wheels in drills are simply horrid, sooo diy ;-) There you are much better off with a sanding disc in a grindette. Sculpt away!
9th October 2012, 19:51
Great feedback, thanks to you all.
10th October 2012, 16:14
Dont forget the PPE ! I have been sanding and cutting and GRP is nasty stuff, disposable dust masks, decent glasses and disposable gloves. Overalls are a good idea so you dont take it into the house A Hoover is useful to keep the dust down. A pair of tweezers to pull the glass splinters out of your hands while you watch Emmerdale. Buy decent sand paper its much better value in the long run. Goodluck
11th October 2012, 19:08
Sound advice Roger, for everyone, you only breath in GRP dust once before you buy a decent mask.
10th October 2012, 17:16
Hi Peepsy,
Very enlightening - thank you.
Sounds like I should do some preparation work over the next few weeks and roll around in my loft insulation in order to get acclimatised!
It is things like this that a novice needs to know, so good work.
Cheers,
Brian
10th October 2012, 18:11
I thought having ichy arms was part of the process.
