Old 7th May 2018, 17:16
Default Radiator Woes
https://youtu.be/W4IHzDRNRPk
Anyone recommend any particular replacement hoses?
Is it worth bothering with silicone ones?
Old 7th May 2018, 19:17
Not sure the superglue will last. Correction, I am sure it won't.
Good news is that there are places that can repair the plastic connections.
Old 7th May 2018, 19:49
IanA's Avatar
IanA IanA is offline
Could be renamed- "Plastic Parts on Modern Cars Woes".
I've had some similar issues with brittle plastic parts on cars over 10 years old - just not made to last...
I always thought that plastic parts on an engine was a particularly nasty trick because the manuf is obviously saying- this is meant to fail and you'll need to buy a new one.
@Landmannnn- where are these places that can repair the plastic connections???
Old 7th May 2018, 19:59
To be honest I a thinking of replacing the radiator when I do the new pipes anyway. It is twenty years old and the bottom half is full of crud as far as I can tell.
Any view on silicon vs rubber hoses anyone?
Old 7th May 2018, 20:13
molleur molleur is offline
I'd stick with the rubber hoses. Silicone hoses have a habit of loosening (stretching) after a few heat cycles unless Tee-bolt clamps are used. Just use rubber hoses at half the price.
Old 8th May 2018, 12:14
Just Google up near you, here is one near me for example http://www.city-radiators.co.uk
Like you I would go for replacement as my first option.
Old 8th May 2018, 15:04
New rad and top hose ordered
