Old 27th April 2006, 14:39
BIG_Fella's Avatar
Unhappy Aftermarket Brake Conversion kit
HELP Please..........
Has any one done a brake Caliper conversion job on there 5EXI
IE: Hispec or wilwood
I would like to fit them as part of the kit build but cant seam to find a kit for the rover 200 bubble 15" wheel
Jerry
Old 27th April 2006, 14:48
Dan's Avatar
Dan Dan is offline
Dan is on a distinguished road
Thought Marlin did a brake conversion? Are you sure you need them, my car stops very very well, and its on standard discs and pads..
Old 27th April 2006, 15:16
BIG_Fella's Avatar
The resane for aftermarket Brakes is the high temps of track use and the high power of the type_r engine
Plus the *BLING* factor hehe.....
I was not aware that marlin did a kit
jerry
Old 27th April 2006, 16:41
Dan's Avatar
Dan Dan is offline
I maybe wrong, just seem to remember the Orange Demo car having a bigger/different brake setup to standard...
Old 30th April 2006, 10:57
Jerry,
For track use I need a bigger rear disc, and a better calliper set-up.
I've sourced a pair of ZR160 rear callipers that have a bigger pad area but bolt straight on to the existing 5EXi brackets. The handbrake mechanism also bolts straight back on.
I'll be testing this set-up at the Marlin open day in Wales 3rd June. With EBC Greenstuff pads should be an improvement. Note I've got a Wilwood pressure valve in-line to the rears ready for this set-up.
If you want bling then the best way to go is Wilwood Powerlites all round with the handbrake mechanism. Marlin can supply the lot. Jerry, on yours I'd get the 10.25" rear solid disc from Marlin at the same time. Job done.
HTH,
John.
Old 30th April 2006, 16:00
MikeN MikeN is offline
I have a set of the bigger ZR160 rear disc's available for sale. I bought them by mistake (needed the smaller size for my calipers). They are 'part used' and the guy who sold them said they had done 150 miles before he up-graded his brakes. I measured them with a mic and they are as new size. Rover OEM.
Regards
Old 3rd May 2006, 15:02
BIG_Fella's Avatar
Wink
Thanks for the replys guys
I think i will have to phone marlin and find out the cost of the bling set
Regards
jerry
Old 3rd May 2006, 21:17
Mike,
I've PM'd you re: the ZR160 brake discs.
Cheers,
