I bolted the trim to the rollbar.
I could see if I bonded it, that should the windscreen need replacing, the trim might end up being a sacrificial component in the process.
I wouldn't worry about water ingress from above the screen..... there are bigger holes it'll find its way through! On the subject of water ingress, whatever you do, make sure you position the screws such that they don't compromise the fit of the hood, and also that when you screw the trim down any hood clips don't press against the glass.
