24th May 2012, 19:18
After my little spin, I've found that I've become very conservative when I approach corners. It's all psychological - I know the back end will stick in the dry when you put the power down, but there's this nagging doubt.
So - do I get over it, be a man and drive it like I stole it, or continue to drive miss daisy?
To try and answer this question, I started looking for grippier tyres - and as most things do when your bored at lunch time, one search leads to another and I found this:
http://www.racelogic.co.uk/index.php...action-control
After market traction control. Who'd a thunk it?
Anyway - it appears to be a straight forward install and setup, and allows you to tailor the amount of slip permissible. It's not cheap - £535, plus the cost of some ABS wheel sensors as it appears to be able to make use of them... But like the dual servo, it could make a big contribution to the feel of the car, and its road holding.
Soooo - driver aids. Only for big girls blouses?
25th May 2012, 06:38
Big girls blouses, definitely. Won't work for me - I've got carbletooters and not fuel injection.
25th May 2012, 22:08
Big girls blouse it is Goo.
What are you a man or a mouse ??????
C,mon these cars are meant to be driven, otherwise you will end up with a mobility car. Even the F1 boys had all that traction control stuff removed so now they have to control their right foot.
If you aren't careful you could end up with a Cabrio or a roadster..................now watch the brickbats coming my way.
May even end up with no one prepared to help me when I pose a question after this.
Get your cars out and enjoy this weather guys.
25th May 2012, 22:56
Do you have an LSD? I find it makes the car very easy to control in loose traction situations - easier (and cheaper) step than traction control
26th May 2012, 07:24
I believe I have an LSD - going by the tag on the diff case. S and then the diff ratio.
Maybe I just need a track day so I can explore the limits.
26th May 2012, 10:33
My 40th birthday present has been fitted - All my mates chipped in to get me a dateless number plate for Vikki. The paperwork arrived yesterday, so I nipped out this morning and got some new plates made up and fitted them:
I always new Vikki was a sassy little minx. Now it's official.
I'm going to get some *cough cough* 'Show Plates' made up in pressed black and silver, and see how I go. If the chap with the brand new Range Rover Evoque down the street can get away with it, I'm sure I can with a car that looks way past pre '72.
26th May 2012, 14:14
I was thinking of changing my name to G854UAM to match the car.
26th May 2012, 19:28
If you lift the back up and spin the wheel, check which direction the other side goes: Same = LSD, opposite = Open.
I've looked on and off for re-build kits (new pads) not found anything off the peg. IIRC LSD's will lock (25% lock on these) for a total of around 10mins in there life so ours are probs getting on a bit!
The dateless plate is awesome, something that's been on my wish list for a while now
27th May 2012, 19:42
28th May 2012, 17:12
Hi Jason. I also "lost it" in my Cabrio soon after I had it. Also on diesel spilled on a wet roundabout, but luckily at about 20 MPH with an empty "on slip" to end up in
It took me a while to believe in the inherently good roadholding of these cars so I used to creep around corners when I first had it. All that changed after a track day organised by Marlin at Landow in S Wales I can thoroughly recommend that as a way to find the car's (and your) limits. I am running on Toyo Proxes T1R 205/55R16s at 20psi all round. These are really grippy and excellent in the wet.
However don't forget the golden rule of not going around a corner faster than a speed in which you can see is safe to stop if required! Peter.
28th May 2012, 17:58
Nice! That wasn't about last time I looked
28th May 2012, 23:22
I go away for a long weekend up to the Lakes, enjoy fabulous weather, and come home to this.......a poke in the ribs!.......and I thought you seemed such a nice bloke at Stoneleigh!
I think it calls for pistols at dawn sir- or at least a Traffic light drag race when we get together!
" End up with a Cabrio" indeed!
29th May 2012, 08:26
I sent an email to the chap who had the eBay auction for the diff parts, to see how much they are without having to fight through the bidding process.
> Hi,
> Please can you give me prices for both standard 25% and updated 40% kits.
> Many thanks,
> Jason
> Sent from my iPad
The reply was pleasantly surprising:
Hello there
25% £67.50
40% £130.00
shipping (UK signed for) £7.00 & £9.50
Regards, D&T
Not very expensive at all - just need to find a source for the other bits - seals, gaskets & bearings.
29th May 2012, 17:25
I wonder if the 40% kit is worth considering for normal road use
29th May 2012, 19:11
Ooppps, I thought it might get a reaction, should have added a few smileys, but I will go for the drag race at dawn.
I am not all bad
29th May 2012, 19:35
30th May 2012, 11:04
I am not all bad
Looks like we might need another of GOO's finds : the limited slip diff
I shall definitely have to get my rear diff support strengthened
30th May 2012, 16:09
Oh, not my find. Patrick had one first. I lucked out as my donor had one fitted.
Here's what I think is a comprehensive list of the parts required to refurb a medium sized diff (188mm):
Input shaft / Flange:
Code:
Diag. # Description Part # Qty
2 Dustcover plate 33*12*1*200*284 1
3 Securing plate 23*21*1*490*120 1
5 Shaft seal 33*10*1*214*099 1
6 Tapered roller bearing 33*12*1*203*615 1
7 Tapered roller bearing 33*12*1*203*616 1
8 Clamping bush 33*12*1*744*368 1
Output shaft / Flange:
Code:
2 Dustcover plate, large 33*13*1*208*006 2
3 Shaft seal & lock ring 33*10*7*505*602 2
5 Tapered roller bearing 33*13*1*213*893 2
8 O-ring 33*11*1*214*144 2
Rear cover:
Code:
3 Gasket Asbestos Free 33*11*1*210*405 1
6 Gasket ring 07*11*9*963*355 2
9 O-ring 33*11*1*206*166 1
I haven't included things like the spacers or 'housings', as you'll reuse the ones you have. Ditto on the input & output flanges and the nut on the input.
Just need to see how much that lot comes to. :/
23rd June 2012, 21:15
22nd July 2012, 19:34
Eee, but it's lovely out there. Just been out for a 3 hour meander through Northamptonshire via the back roads, with a stop off for tea. Smashing! 8D
