9th April 2018, 16:55
Told you I should have come to look at it!!
it's possible that you may have to remove a leaf like I did - that'll make it lower for sure - but until you drive it there's no way of knowing if the ride is too hard or not I suppose.
10th April 2018, 07:53
Hi Paul,
Yeah see what happens when I'm left to my own devices!!
I've left the bonnet propped up for a now in the corner while I do some more mechanical jobs.
I'll get back to it when there's more time to concentrate, as I need to know the body is correctly located before I forge on with finishing off the bulkhead to allow brake lines, cylinders and all the pedals to go back in.
Steve.
10th May 2018, 08:27
Gents,
A bit of advice on the rebody process and DVLA application please, to avoid any pitfalls / obstructions that others have fallen foul of.
Is it a V627/1 form that I use, and what other supporting doc's are required?
With the body on and bonnet, doors and boot fitted can I apply now?
I've made them aware of the engine change to 6 cylinder and had the V5 back for that.
All advice appreciated please - hopefully a lot simpler than the IVA I went through last year!!
Cheers in anticipation
Steve.
11th May 2018, 06:26
Hi Steve
If memory serves me, together with the fully completed V627/1, I sent two photographs, ¾ views front and rear showing the number plates, the soon to be old V5C, and the original receipt for the purchase of the body from Tribute.
I don't have time to search for it now, but I recall a learned post somewhere on the forum which stated authoritatively that, in the photographs submitted, 'It just has to look like a car'. These are the two which I sent.
Regards, Mick
11th May 2018, 06:43
Thanks Mick.
Can you remember is they're bothered with a current MOT or insurance, or just the V5?
If it's as simple as that I'll apply now and leave time for any problems or inspections that may come along.
While I've got you as well, are the rear stop / tail lights Morris Minor? They don't look like the early Spit ones??
Steve.
11th May 2018, 07:34
You can do the V5 changes with just a V5c , no MOT or Insurance documentation required . Only one of the pictures needs to show the number plate , but I tend to hang it on the new body , even if its just taped or cable tied ...
When filling it in , in the extra notes section be sure to stress that the vehicle is a re-body only , no chassis or running gear changes have been carried out and its just the replacement bodyshell . Also , state that as per DVLA current regulations , this entitles you to retain your original reg. no. vin no. and classic car status but the model name must change to reflect the new bodyshell , which is a ****** .
I tend to quote an example thats already been done as a reference too ...so quote Micks reg no. or something ...
I know it seems over the top to keep stressing the same thing , but there are people in these depts that have not done very much of this at all ...and giving them a little nudge to how it works and a previous case they can read the notes on , if required , can't do any harm and might just save you getting a letter from someone who has gotten the process all wrong .....I have had to explain on the phone how they need to do it before , after getting info back saying IVA required !!
11th May 2018, 07:45
Hi Steve
I've done a couple of these now, in addition to the V627/1, V5 and the photos Mick suggested I also sent a picture of the original car showing the number plate and a covering letter explaining that the original chassis or monocoque body has been retained and unaltered. They are also very keen on having a receipt for the body kit.
I have never included MOT or Insurance information.
Best regards
Neil
P.S. Keep a copy of everything you send them, this process is not their "bread and butter" so it can get shunted around case workers a bit and could easily get lost.
11th May 2018, 07:50
Cheers LL, very helpful.
I know exactly what you mean about DVLA. When I had passed the IVA with the Tiger ERA, I applied for a V5 using the Tiger chassis number which was an approved standard, on a plate and welded to the new powder coated chassis.
They began by insisting that this should be ground off and a new one of their choosing made up and welded on.
Several letters and a phone call from Jim at Tiger eventually saw sense prevail, but really highlighted the pen pushers real lack of understanding of the industry or the process involved.
Your 'expect the worse and you can only be pleasantly surprised' approach makes perfect sense.
Once again thanks.
Steve.
11th May 2018, 07:53
Cheers Neil,
Exactly the info I needed.
Steve
11th May 2018, 08:04
Yes , as Neil says , picture of original donor vehicle showing its number plate is compulsory ...2 pictures minimum , one of original , one showing new body ...
Guys buying rolling chassis will struggle with that one a bit ..especially rolling chassis with very old V5's ..as that will flag up extra questions ...
And definitely photocopy everything ....and make a note of when sent and also invest in special delivery ...they have been known to deny getting documents at all ...hard to dispute if someone signs for it !
I had a case that was going on and on ..chased it and eventually got a call back saying no documentation could be found ..I needed to re-submit everything ...little hard to do when they have your V5c ..so advice was include £25 for a new V5c !! then , genuinely , 3 days later , a different lady calls me and says ..'' I'm just processing your application and ..... '' They are a bit special sometimes ...
11th May 2018, 09:44
I think people have had success in the past by sending their documents to:
K and R
DVLA
Swansea
SA99 1ZZ
K and R means Kits and Rebuilds. The staff in this department probably have more experience of these situations.
The direct telephone number for this department is (I think) 01792 786053.
I hope this helps and sorry if you already knew it.
11th May 2018, 16:11
I think everyone above has covered this already.
But I can confirm that I got my V5C updated before I'd bonded on the new body shell.
(Although, obviously, the body shell was in position for the photo.)
The key point was that my car was definitely no longer a Spitfire.
12th May 2018, 06:25
Rear Lights
While I've got you as well, are the rear stop/tail lights Morris Minor? They don't look like the early Spit ones?? Cheers Steve.
Hi Steve
They're Lucas L549s as used on both MGAs and D-Type Jaguars in period. I bought mine from Europa Spares
Regards, Mick
p.s. Also found this .
13th May 2018, 07:48
Cheers Mick.
I got the lights sorted, and in the end settled on the L549's as you did.
Also thanks for the paperwork info, I'm sending it off today so I'll update on the forum once I get feedback or approval from them.
Steve.
28th July 2018, 18:55
Evening gents,
Recently fell out of love with the build process and left it alone for a few weeks after an intensive few months. Having viewed others build and on the road threads on the forum, it reignited my energy for the project.
So decided to attack the interior. The rank spitfire seats were stripped down and recovered with new foam, and a new dash installed with a mixture of old and new smiths gauges. Not sure if i'm happy with it, maybe its a bit fussy and not race car but I can always change it later.
Anyway, update photo's,
IMG_1841 by Steve Ward, on Flickr
IMG_1840 by Steve Ward, on Flickr
IMG_1839 by Steve Ward, on Flickr
IMG_1837 by Steve Ward, on Flickr
29th July 2018, 01:10
Nicely done!
29th July 2018, 07:29
Wardy50 – Hi Steve,
There will always be highs and lows on these kind of build, so taking a break is a good idea.
I walked away from my boot lid project several times in frustration until I finally cracked it.
Your new interior and dash both look great.
The big advantage of this style of car is that you can get away with a full range of finishes.
From the spartan fighter plane look to the posh Gentlemen’s club and everything in between.
Just spotted the cockpit panelling too.
That is something else on my own “To Do” list.
29th July 2018, 11:20
looks very tidy ...it takes a long time to do decent aluminium panelling ...yours looks pretty good ...
29th July 2018, 19:25
Looking good!!
29th July 2018, 19:47
Looking excellent keep up the good work.
