Old 6th October 2013, 18:17
morris's Avatar
morris morris is offline
Default instrument panel lower radius
Evening all. I've a simple question about the IVA rules on the radius of the bottom edge of the instrument panel. The IVA in section 12 RS7 states
"The instrument panel lower edge within the “specified zone” must have a radius of curvature not less than 19mm or 5mm and be covered with a non-rigid material, except where an adaptation for a disabled person makes it impossible to comply. (see notes 6 & 7)"
I read that as:
- if your dash is solid e.g. wood or ali etc it needs 19mm radius
- if your dash is covered in foam and vinyl / leather it can be 5mm.
It's not a very well constructed sentence so I spent a good 5 minutes thinking "well what is it, 19mm or 5mm?"
Just wanted to double check my understanding before wasting time doing the wrong thing.
Old 7th October 2013, 07:00
Chris Cussen's Avatar
Well to be sure I got through IVA I got some cold water pipe foam lagging (which has a split in it), covered it in leather cloth and slipped it over the bottom edge of the dashboard. Since my dash was black leather cloth anyway I've left it on.
Old 7th October 2013, 12:03
NigelB NigelB is offline
NigelB is on a distinguished road
Ian,
I THINK you've read it correctly. As you say, it's a lousy sentence.
I chanced my arm a bit but got away with it. My dash is 12mm solid walnut. I routed out the bottom 10mm of the dash to 6mm thick and radiused the edge to 5mm(ish) I then put an edging strip on it (same as the edge of the cycle wings) and the tester was happy.
But another day, another tester, who knows............
Nigel
Old 7th October 2013, 16:59
morris's Avatar
well I was planning on fixing a rounded profile on the bottom using some thick beading and then covering the whole lot in foam and leather anyway so sounds like as long as it's over 5mm, which it will be, I should be ok. I just didn't want to have to try and find 19mm plus beading.
thanks
Old 7th October 2013, 17:12
Patrick's Avatar
Patrick Patrick is offline
I did the same covered it in speaker carpet - sva man was happy.
