Old 18th February 2005, 12:37
Default Rear Suspension Links
Hi,
I've just started trying to set some base camber and toe settings on the suspension.
The rear toe links appear to be too long...has anyone else found this?
I.e. there is not enough thread to adjust the rear toe...
Marlinturbo
Old 19th February 2005, 17:39
Barry Barry is offline
Kit Car Dreamer
Barry is on a distinguished road
Default suspension
I have been advised by Mark at Marlin to cut 10mm off the ball joint spigot,apparently there is plenty of thread to allow this.Hope this helps
Old 19th February 2005, 17:59
Hi Barry,
Yes you are referring to the ball joints that set the camber, and yes I have cut them down approx 10mm. This is essential else they contact the driveshafts...
However, I am referring to the linkages that are connected from the upper triangular tube section to a ball joint at the rear of the hub...I really do need to get my web site finished...
The linkage is constructed of a tube with a threaded bar at one end and a flat plate with hole on the other end. Does that make sense?
marlinturbo
Old 20th February 2005, 08:11
Kit Car Dreamer
Hi John
Yes the internal thread in the ball joint that connects to the threaded bar is the one I was refurring to ,if 10mm is cut off this, it allows the threaded bar is be inserted enough to allow adjustment .Hope this helps
Old 20th February 2005, 14:41
Barry,
I'm there now...just takes a while...of course tis obvious now.
Right time to get the angle grinder out yet again...
Thanks Barry.
MarlinTurbo
