Old 20th November 2014, 16:15
CarNoob's Avatar
CarNoob CarNoob is offline
I like your solution to making drain points.
Old 20th November 2014, 16:51
Viatron Viatron is offline
Nice work as usual mate, keep it up.
Mac
Old 21st November 2014, 15:28
CarNoob - Cheers, I just hope I can remove the "mould" when the time comes.
Mac - Thanks.
My youngest daughter was off school sick today, so I have no problem with having no car work to report.
However, I do have something to report...
Close, But No Cigar:
The good news is I got my revised V5C back today, but the bad news is that the Model name was merged with the Make.
And in order to make both names fit on the same line (i.e. limited space), the Model name was shortened to something I would not have picked.
So I have just amended the new V5C, signed it and sent it back for what I really hope will be the last time.
Old 22nd November 2014, 10:06
Weather 1 - Build 0
I'd cut out more of the yoga mat & covered the front edges in parcel tape.
Put as soon as I stepped out the door, it started raining again.
When it finally stopped, I just peeled the covers from the back of the body shell.
I managed to get as far as fitting the foam moulds.
You will notice I am also using some cardboard to help me build up the height of the top lip.
( This is because the rope re-enforcement was in the way of the grinder, so it was cut too short. )
I even had all the matting required cut & laid out ready to start.
There was even a bit set aside to add to the drain holes from underneath.
But then the rain returned.
The last time I got caught out by the rain while fibre glassing made a right mess.
So I admitted defeat and packed everything away.
Given the forecast for the rest of the weekend, I don't think I am going to get a chance to do this work any time soon.
However, I'd prefer to wait and do a half decent job, rather than rush it.
Old 22nd November 2014, 18:42
Monday looks good on the BBC forecast Paul, you may be okay then!
Old 24th November 2014, 14:21
Scottie - Thanks, today's weather was much better.
Slowly Edging Forwards:
Spent most of the weekend down in Sussex for my mate's birthday bash.
As we drove home through the pouring rain yesterday, I did contemplate the wisdom of building a car with no roof.
Still, at least it wasn't raining this morning, so I finally managed to get some car work done.
When I peeled off the covers, it was clear I have put the rain channel drain holes in the right place, as that is where the water gathers.
I also put the boot lid back into position to check the gaps I needed to fill & thankfully it is just the centre section.
Note:
The lid is sitting a bit higher at the moment due to the fact I haven't trimmed back the re-worked bottom corners yet.
So one small fibre glassing session later and this is what the rain channel looked like.
Given how cold it was, I decided not to attempt any upside down fibre glassing, as it was bound to end in tears.
So I waited until the first round was initially set before turning the body shell over.
I wanted to build up the "pipe" section of my drain holes...
And add a bit more "cross bracing" to the top edge bolt mounting plates.
One part of this plan went well.
But the other turned into a complete mess.
Somewhere along the line, water/moisture got into the resin/matting for the drain holes.
When I saw the matting going "milky" I knew it was time to stop, abandon ship and remove everything.
As it turns out, this may be a blessing in disguise, as getting the matting around the cable was a real struggle.
So I may have a look for small section of plastic pipe and 'glass that to the bottom of the "funnel" instead.
It was only when I moved the shell out of my wife's parking space did it dawn on me what went wrong.
I removed the foam formers from the rain channel.
There is still a bit of work to do here, but at least the basic shape is in place.
As I wasn't going to be using the cable in the drain hole, I removed it and most of the plastercine.
Trapped water kept leaking out while I was doing this, so that was the source of my earlier problem.
My next job will be to tidy up the inside edge of the rain channel so the rubber seal will fit.
I will also be adding some filler to provide a smooth surface on the bottom of the rain channel.
I can't really complain too much about the conditions on the front drive.
As my mate in Buffalo sent me this photo of the front of his house!
Old 24th November 2014, 18:49
swifty's Avatar
swifty swifty is offline
Paul the rain channel is certainly coming together now, i was thinking along the lines of bonding in a plastic insert into the channel corners then attaching some silicone tube to take the water away.
That snow at your mates looks fantastic, my kids would love that and most likely try to build an igloo like we did a few years back when the snow fell hard and deep up here.
Keep up the good work it's getting there.
Old 25th November 2014, 13:01
Swifty - Thanks for your support & encouragement.
My girls also love the snow, but living in London it is rarely very deep.
So we tried to make the most of it when it really came down back in 2009.
Barely Making Progress...
Weather and other stuff is conspiring against me at the moment, but I started tidying up the rain channel.
This involved a lot of checking, marking, trimming, test fitting and repeating.
Rather than move the body shell, I just propped up the rear end so I could crawl underneath.
Although next time, I think I will actually take the time to dig out my axle stands.
Eventually I got to the point where I could test fit the rubber seal.
And here you can see how the seal will by-pass the top edge bolt mounting plates.
Obviously I still have to trim a bit more off as the lid doesn't sit flush yet.
Question:
- Should I use the weight of the lid to determine the right level for the rubber seal?
- Or should the lid sit a little high, until it is pushed down when locking it?
I'd rather take my time and reduce the height of the lip slowly, rather than trim off too much at this stage.
But if I look at Swifty's boot opening, the lip for the seal looks quite small to me.
DVLA Update:
Spoke to the DVLA today & the original Model section of my V5C has to stay blank.
So the new Model name has to be added to the Make line next to Triumph (as per Dave's Miglia).
The good news it is easy to modify the name I picked so it fits into the space available.
Which means that everything should now finally be in order.
Old 25th November 2014, 14:21
DVLA Update:
Old 25th November 2014, 16:19
How 'squashy' is the rubber seal?
If it's anything like the foam strip I put under the rear edge of my bonnet you might find that the seal will need to sit at a level where it leaves the boot lid flush with the body surface rather than leaving it proud and compressing it with the locks.
The issue is that the foam, which is easy to squash at any point with your fingers, doesn't compress anywhere near as easily when it's an extended flat surface that's trying to squash it. Hopefully your seal will compress more easily along the rain channel.
Old 25th November 2014, 16:45
Paul my gut says let the lid sit a couple of mm high then let the catches pull it down. That said how water / air tight does it need to be? with the depth of the rain channel you would be unlucky to find more than a few drips making it down the channel and up the other side and then up and over the seal?
Mac
Old 25th November 2014, 17:51
swifty's Avatar
Paul i set mine up the way Viatron has said, the lid sits a little high under its own weight so will pull down when locked, if its the same seal from CBS as i have then it has about 8-10mm compression.
Hope that helps.
Old 26th November 2014, 08:19
Hey Paul I love the snow Wallace!!
On the bootlid, there are two issues to consider:
One is water tightness
The other is looks
As you are building a car with no roof, and don't intend to wear a wet suit, when you pose about in it, looks take priority!
So whatever you do, it has to look right when its just sat on the drive with the boot lid in place.
Its looking good, and I think we all know the finished car will be quite special.
Old 26th November 2014, 12:26
Dave - Thanks, although I'd certainly recommend everyone follows your KISS DVLA approach.
Mr T, Mac, Swifty & Scottie - Cheers gentlemen, that all makes sense.
As when I did my first test, the weight of the lid easily squashed the very small section of rubber seal I used.
Clearly when the full length of rubber seal is in place, the same weight of lid will not squash it down as much.
Guess I really should have paid more attention during those Physics lessons at school.
So I will continue to trim the lip a bit at a time until the lid seals nicely when locked.
Play Misty For Me...
The dampness in the air is stopping the rain channel from drying out enough for me to add some fibreglass filler to it.
And I want to use the filler to consolidate the lip a little bit before I do any more trimming just to ensure it will not crack / break.
So instead I spend ages looking through my pile of boxes in the Summerhouse before I could finally track down the original fog light switch.
I knew I had put all the bits in a jar (just in case I ever got around to selling it on Ebay), but I really need to check & re-label all the boxes.
( As it is no good keeping things if I can't find them when I need them!)
I have plenty of spare wire, so I just need to study the wiring diagram again to work out the best way of re-connecting the fog lights.
I will also need to drill a hole in the dash board and will probably use the original choke hole I filled in (bottom left of rev counter).
The original fog light switch was fitted beneath the oil pressure gauge in the photo above, but I moved the choke lever over to there.
Last Big Jigsaw Pieces:
It is great to see paint going on Mac's car.
However, it does remind me that I still have a long way to go & I really must finalise my plans for the body shell / bonnet.
So I've been looking back at these photos of the original Ribble Cordite demonstrator at Stoneleigh 2013.
As there is no escaping the fact that my own 13 inch wheels will also look "lost" in the front arches.
In addition:
- The small section of body shell that extends beneath the bonnet is a different length on both sides.
- The sloping angles at front of the body shell, where the bonnet sits, are also different on both sides.
This last point lead me to build the new scuttle bonnet lip at a slight angle so the two sides of body shell would meet up.
Finally there is Spitfire chassis issue which seems to stop the Cordite/Navigator bonnet from opening as far as a Spyder one.
E.g. Mister Towed
As with a lot of issues I have faced on this build, I can't fix one thing without a knock on impact on many other things.
Bonnet Plan:
- Sort out the hinging arrangement.
Clearing the chassis may be helped if I pull the bonnet forward & down a bit (compared to the Cordite demonstrator above).
Whilst this would move the position of both the wheel arches & rear edge, these areas already need work (see below).
- Follow Mac's approach and cut/extend the driver's side to cover the wheel.
- The rear edge needs to be re-profiled to match shape of the my body shell's new scuttle area, using a similar "slit" technique as Micky1Mo.
- Create a "tighter" opening in the wheel arches to match the wheels & tyres I am going to use.
- Extend the nose/grille opening to provide a square front edge and a deeper lip to support the grille.
- I might also need to build a small "bubble" over the brake master cylinder depending on how the other work goes.
Body Shell Plan:
- Cut the lower rear sections of the bonnet off to extend the body shell, as per Mac & Michiel.
This will allow me to set the same gap between the body shell and tyres on both sides.
It will also give me the option of fitting side repeaters as they will no longer highlight the different gaps/angles.
- "Square up" the bonnet lip on the scuttle so it matches the newly formed body shell extensions above.
Given all the remedial work I did at the back of the car, I might as well make the front square as well.
Writing down a "To Do" list that is clearly going to involve a ton of work may seem like madness.
Especially when I am currently struggling to finish off the boot lid work at the moment.
But if I want to finish the car, then I just need to have a plan and keep chipping away until all the work is complete.
Old 26th November 2014, 13:58
Paul, my bonnet opens that far because of the 'scissor' brackets I made -
These allow the bonnet to pivot from the lower edge and lets it open much further than if it pivots from the centre as with my first attempt. Just make sure that wiring/fingers/cats tails are kept clear when closing it.
Can't see any reason why the same design couldn't be adapted for use on the Spitfire front cross-member.
That no.47 sure is a great looking car btw.
Old 26th November 2014, 20:31
Mr T - Thanks for that photo, as I really think that might be the way I need to go.
Can I ask a couple of quick questions?
- How thick is the steel you used?
- Is there a washer between the two sections?
Old 26th November 2014, 21:01
The brackets are 50mm x 5mm strap iron and there's no washer between them, just a bit of axle grease.
Old 27th November 2014, 14:27
Thanks Mr T.
I've now re-read the part of your build thread that covered both your MkI & MkII hinges.
I'll certainly bare in mind the fact you had a small fire while trying to weld to the bonded in hoop.
Although I do take comfort from the fact you were able to remove the MkI hoop.
As I've always assumed that removing my "factory fitted" hoop & hinge point would cause too much damage.
My factory hinge points were fixed to the middle of the nose, whereas Mac, and others, have hinged theirs much lower down.
Either way I am planning a Blue Peter style engineering experiment with some cardboard cut outs to test my options.
So if your scissor hinge arrangement allows my bonnet to clear the chassis I will be a very happy bunny.
Comparing Mac's bonnet to yours, it is clear that having the Herald chassis in the middle of the Spyder's bonnet nose is a big help.
Old 27th November 2014, 20:25
cbjroms cbjroms is offline
cbjroms is on a distinguished road
Paul,
Are you planning to stay on 13" wheels or swap to a larger diameter? I am just thinking about my rear wheel arch clearance and whether to reduce by means of a cut & shut. My preference would be to go for 14" wheels as the wheel/tyre size thread suggests that 14" is doable without any clearance issues.
So I am thinking that 14" (as Trevor used in the first Sammio Spyder build thread) is the sweet-spot to avoid clearance issues and wheel arch mods. Problem is I am not sure what 14" wheels are available with correct offset and PCD other than the steel MGF spares which look pretty basic.
Chris
Old 28th November 2014, 17:24
Chris - I'm going to stick with the brand new 13" wheels and tyres my donor came with.
I know this means more work in some areas, but the smaller wheels should keep the car a little bit lower.
Given that I'm only 5' 8", with a 30" inside leg, I'm keen to avoid the need for a step ladder to climb in!
It Has To Get Worse Before It Can Get Better...
I peeled the covers off the boot opening in the vain hope that it might finally dry out.
Then I spend ages staring at the bonnet in an attempt to work out what I need to do to make the hinge work.
There is simply no escaping the fact that this bonnet was not designed to play nicely with the Spitfire chassis.
Based on Dave's research with ACE, I am now happy that the original chassis does not include the outside edges.
So a quick trim with the angle grinder and I had this.
Based on DonnySoutherner's Cordite, I believe you can cut off the outside "shoots" as well, but this will do for now.
Although at this point the bonnet still will not fit as the area below the grille opening is in the way.
I propped up the bonnet to get a rough idea of where I wanted it to sit.
In this position there is still a small gap above the radiator, including the cap.
If I was ever going to find a way to hinge the bonnet, I needed to do some more drastic surgery.
So out came the grinder again and I got to work.
With this section removed, the bonnet can get a lot closer to the chassis.
But I still need to do some fine tuning to clear these end sections.
End of Part 1...
