8th November 2006, 19:34
Demister vents
I am getting ahead of myself here but I will soon be installing the scuttle top and I wondered what everyone else had used for demister vents. The scuttle top is very curved and I can't see the standard vents (like fiitted to a mini) fitting as they are straight and don't look like they will bend too easily...
9th November 2006, 09:23
vents
Demister is only required for SVA if you have fitted a windscreen.If you go thru SVA without screen, you can fit it after and not fit a demister;all down to personal choice!
10th November 2006, 14:33
Could you cut the hole and then use bendable chrome trim (I think CBS sell this sort of thing?)
15th January 2007, 22:11
I thought I would resurrect this thread, again.
Has anybody got a solution for fixing the demister vent pipes from the heater to the scuttle?
thanks
15th January 2007, 22:36
vents
16th January 2007, 07:45
I was thinking about moulding something into the underneath of the scuttle - but haven't got any further than that. Perhaps a 2" plastic pipe cut in half lengthways. You could then put the slots in the scuttle for the hot air anywhere you like within the width.
3rd November 2008, 21:56
Reviving this thread to see if anyone out there has actually fitted any demister vents in a Sportster?
I need to find some chrome or polished stainless vent surrounds that can be formed to match the curve of the Sporsters scuttle.
Any ideas or experience welcome,
thanks
10th February 2009, 22:14
I've been taking another look at this today. I've got the fan tail vents off a mini but my speedo/tacho are in the way and the scuttle is curved, so not easy to fit these.
I've had a go at cutting a curved slice off the side of a piece of 40mm waste pipe but there is not much space between the dashboard and the windscreen itself so not sure yet if this will fit and a couple of the dash mounting bolts are just where you want the vent??
11th February 2009, 19:45
Prototype demister pipe
The plan is to glue and bond this under the demister slot. The 90 degree bend has to fit between the Speedo and other gauges on the dashboard.
I cut one of the demister slots today. (what a messy job!)
I've also shortened the two dashboard fixing bolts so hopefully they will fit OK.
(P.S. the holes you can see here are for the wiper spindles.)
11th February 2009, 20:40
Looking good I've got a set of vent I bought from CBS a good while ago, they are metal funnel type things. We'll be looking at putting them in soon as well.
13th February 2009, 18:32
Have you found a suitable location for the windscreen washer bottle? My engine bay is so full you couldn't get a matchbox in there... I seem to remember one of the Marlin built cars had it located in the boot!
13th February 2009, 22:53
Hi Robin,
not really looked at that properly, yet.
I've seen one in the boot and one down by the exhaust manifold which didn't seem a good idea but I guess it stops it freezing up in the winter.
I hope it'll fit in here behind the alternator opposite the oil dip stick?
I've got a nice shinny push button to go on the dashboard........
https://www.europaspares.com/ELECTRI...503__2040.html
14th February 2009, 09:48
I was thinking under the header tank might be a good place
14th February 2009, 22:33
unfortnately that space is already taken with my fuel filter!
I've added some fine stainless steel mesh to the back of the vent trims.
It stops anything dropping down the slot and looks really smart.
In case you are wondering where I got the mesh its "VIVARIUM reptile stainless steel mesh "
"............ideal for vivariums and terrariums where high air flow is required ......"
14th February 2009, 22:56
It look great, the mesh really finishes it off nicely. The surrounds are from a mini ?
15th February 2009, 10:52
Looks great Peter. Is there a lip / higher rolled edge on one side of the chrome surround? It looks like it from the pics.
I only ask because if so, wouldn't that need to face the windscreen rather than the dash, to deflect the hot air onto the screen rather than the cockpit?
15th February 2009, 20:53
Yup, they are mini vent surrounds from minispares.
No, the surrounds edges are the same and essentailly flat, but I can see why say that. It's just an illusion of the camera angle.
18th February 2009, 16:18
I bit more progress on the demister vent tubes.........
Here is an overall shot. The aluminium tangs are to hold it in place pending a full fibre galssing at some point in the future.
Of course, its only the digital camera that can see it like this! i had to bond it in place by feel.
...........there are more details on my flickr site.
21st February 2009, 19:54
Here you go...........
The heat from the radiator should keep the washer fluid nice and warm
It's fixed in place but now i've got to find a route for the pipe and cables back through the bulkhead..........
