27th September 2009, 03:57
Day out at Woodbridge
Hi everyone.
Went to Woodbridge airfield today to meet up with Matt in his 5exi. Had a fantastic day there. Car was running low boost (about 7psi) but still managed on the straights to keep with the vx220 turbo's.
Matt's driving through the bents pushed the car to the limit (even spun without drama). And all this on the original mk1 suspension.
Quite surprised. No lift off jerking etc. Only difference at the rear I think is that the car has bigger and wider wheels. But handled great.
Got me a little worried now though. If you can break traction with low boost, when mine is on the road, I'm going to have to be very careful.
27th September 2009, 16:20
Any pics John?
27th September 2009, 16:31
Matt has some good ones and some video with camera attached to the car.
Once I get them from Matt, with his permission, I'll post them up.
27th September 2009, 21:36
just joined the forum tonight and am a little worried by the stories of poor handling. i bought one of the very early cars ( 2nd batch manufactured ) and chose to fit it with the rover 216 ( honda ) engine. i find the handling of the car a bit nervous at the front but have not noticed anything from the back. when cornering hard on bumpy surfaces the front tends to wander off with each bump. has there been any suggested fixes for this problem at the front. am presently preparing a new engine to drop in the car over the winter, have sourcd a honda d16z6 engine from a honda crx, engine is the vtec version. have spent many hour refiguring the wiring to use the original ecu and fingers crossed it all works
john
28th September 2009, 04:52
Hi John.
Welcome to the forum.
I beleive Marlin changed the front end slightly and added an anti roll bar. Best to contact Marlin for all the changes. What tyre pressures are you running as this can have a big effect on the handling.
Ian (Merlinman) has done what sounds like the same engine as you (216 gti Honda dohc). But is finding it noisy at motorway speeds. So he will be interested on how your VTEC swap will turn out.
28th September 2009, 15:52
Found this picture of the Marlin. The picture does not do the colour of the car justice though. It's more of a pearlescent purple. Nice colour.
http://javelintrackdays.co.uk/jt/ind...=2205&Itemid=3
29th September 2009, 20:26
Kit Car Dreamer
Poor front handling
[QUOTE=sylvazx;16896]just joined the forum tonight and am a little worried by the stories of poor handling. i bought one of the very early cars ( 2nd batch manufactured ) and chose to fit it with the rover 216 ( honda ) engine. i find the handling of the car a bit nervous at the front but have not noticed anything from the back. when cornering hard on bumpy surfaces the front tends to wander off with each bump. has there been any suggested fixes for this problem at the front. am presently preparing a new engine to drop in the car over the winter, have sourcd a honda d16z6 engine from a honda crx, engine is the vtec version. have spent many hour refiguring the wiring to use the original ecu and fingers crossed it all works
john,
Built my car about four years ago but i have not played around with it much. One thing i did resolve last year was the front handling. My car was suffering from "bump steer". Apparently when you go over a bump the steering arm geometry changes and pulls on the hub and moves the wheel left to right. You can get over this problem by adjusting the arm that connects the track rod to the hub. I believe it has an elongated hole for this purpose.
i jacked the car up removed the damper and strapped a laser level to the wheel, locked the steering wheel in a straight ahead position. Then where the point of light shone on the garage door i drew a vertical line. As i moved the suspension up and down i could see the point of light moving away from the vertical line showing that the wheel was being pulled by the steering arm. i then adjusted the link arm to minimise this movement. i did have to elongate the adjuster hole to get it spot on though.
i hope thats clear but if not let me know and i will try and be a bit more precise.
30th September 2009, 09:29
Thanks for all the replies.
The fuel pump on this car cam from a rover 416 ( honda engine) and is separate from the fuel gauge and does not contain any sort of resevoir or surge pot. i may have therefore caused my own demise by using this pump. However i am removing the tank over the winter to fit baffles as the track days i want to do with this car have some long bends and due to amount of fuel used at these speeds feel i am safer with the baffles.
As for front suspension, yes the holes are slotted on steering arm and adjusted it to put track rod end in middle of the suspension arc of movement but may have got wrong. great idea with the laser to check toe in/out, got one for a xmas present and never used it, will give it a try.
29th September 2009, 20:21
John,
Welcome along.
Does your fuel tank not have the standard Rover pump/swirl pot assembly in it? The pump housing incorporates a sort of jet pump pickup into a hinged swirl pot with enough fuel in to feed the pump for a long time so surge shouldn't really be an issue in that case, hence no need for Marlin to baffle the tank.
On tyre pressures, I think most people on here are running more like 15 - 18 front and rear so that might help. Tinkering with the steering arm heights to minimise bump steer pays dividends in improving the handling over bumps too - have a search on the forum for where it's been discussed before.
Richard
