Old 31st January 2008, 07:43
shadow rs shadow rs is offline
Kit Car Dreamer
shadow rs is on a distinguished road
Default help with wishbones
hi everyone.
i am in the process of designing a new kit car car, most of it will work like the ariel atom (although it will look nothing like). My problem is i am not sure on the wishbones, do the top ones need to be a different length to the bottom or can thy be the same lenght, also i have read that f the top one is angle upwards it will help antidive.
any help is appreciated. please go easy though cause i get lost with lots of figures.
Old 6th February 2008, 22:21
kitkarman's Avatar
kitkarman kitkarman is offline
Kit Car Dreamer
kitkarman is on a distinguished road
Depends if mountings are vertical,if so wishbone at top will need to be slighltly shorter to allow for some neg camber,also depends on uprights if they are vertical when mounted ie ball joints same top and bottom
Old 6th February 2008, 23:23
Patrick's Avatar
Patrick Patrick is offline
Would it be worth getting a book on suspension design and theory (there 5 or 6 on amazon)?
From my little understand of the subject it seems to quite complex to get right
Old 7th February 2008, 07:08
Kit Car Dreamer
i have just ordered How to Build and Modify Sportscar and Kitcar Suspension and Brakes for Road and Track so when it gets here i will let you know.
the monts are vertical and the hubs will be the rally design kit based on cortina uprights. the mounts can be altered if need be.
Old 7th February 2008, 20:27
kitkarman's Avatar
Kit Car Dreamer
well there is castor, camber and track really the first ron chapman how to build a sports car for £250 gives you an idea of what is needed in simple terms then you can build on that, just make everthing adjustable a little.
http://www.kitcarland.co.uk
Old 7th February 2008, 20:33
kitkarman's Avatar
Kit Car Dreamer
more important to have rack mounted in correct place to eliminate bump steer than anti dive for normal use i would say.
Old 7th February 2008, 20:38
Kit Car Dreamer
i recieved the book i mentioned earlier, from what i have looked at so far i think it will tell me what i need to know. thanks for any advice.
