Old 18th February 2009, 07:47
Ex-Biker Ex-Biker is offline
Default Rover 1600 K series Question
Just filling in the SVA form, but can't seem to find anywhere the 'Maximum power engine speed'.
I can find torque figures, max revs, max speed etc, but not power @ revs.
Can anyone help?
Also has anyone got the axle & gross weights for the 1600?
Old 18th February 2009, 10:38
It doesn't have to be exact so max torque will probably be around 5-5.5k and max hp at about 6.5-7k I would have thought.
Its only for the emissions and noise testing but tbh when the tester did mine he just told me to take it to x rpm without looking at the power figures
Old 18th February 2009, 12:13
SDMC001's Avatar
SDMC001 SDMC001 is offline
These are the figures I used
Mine was 1996 P reg 1.6 Sli...so should be the same:-
Max road speed = 118mph
Max power engine speed = 6000rpm
Max net power = 82kw
Cubic capacity = 1589cc
A1 450 KG A2 550 KG
When the car was weighed with a full tank it was around 800 KG
Steve
Old 18th February 2009, 12:32
alackofspeed's Avatar
My Honda-engined car was nearer 700kg, are you sure of that figure Steve?
Old 18th February 2009, 13:05
Bang on Steve
Mine's basically the same donor car (96P 416Sli).
Seems a bit heavy though. Does it matter too much if you are a bit out with weights etc?
Old 18th February 2009, 13:17
as long as your design axle weights are more than the measured weight you will be ok, but it shouldn't be too far out. If you are out, then if the tester is nice you may be able to change the form to be right
Old 18th February 2009, 13:20
SDMC001's Avatar
OOOOPPS, something I forgot, I was siting in the car when it was weighed, it puts the weight around 700 k as was Johns. The axle weight was provided by Marlin.
Steve
Old 18th February 2009, 13:18
should add that my Shelsley was 850kg inc fuel plus 150kg for two passengers
