Old 11th September 2013, 10:04
GET-GO Auto Spares GET-GO Auto Spares is offline
GET-GO Auto Spares is on a distinguished road
Default NEW Richmond Six Speed NEW Edlbrock heads & much more!
Richmond #7041626
For sale is a Ford Richmond Six Speed overdrive transmission (#:7041626) NEW
The Richmond Six Speed overdrive transmission was designed with the driving enthusiast in mind. he six speed transmissions made in the U.S.A. by American Craftsmen using the latest CNC machining and in house heat treat. Based on our bulletproof five speed design, the Richmond ROD has another gearto-grab overdrive!
£2750.00
McLeod#673-8624
Standard SFI Bellhousing 1965-78 Ford Small Block 289/302/351 NEW
McLeod Standard SFI (spec) bellhousings offer the tightest tolerances available for consistant, accurate fit. Most bellhousings are designed to fit multiple engine and transmission combinations.
£255.00
McLeod #463100 - McLeod Steel Flywheels NEW
Steel Flywheel
1964-1969 Ford 260/289
0-Balance
157 Tooth
The McLeod steel flywheel is perfect for street applications where easy stop light acceleration is desired and for off road or rock crawling. Steel flywheels come in various weights and and dimensions. For race applications, a heavier steel unit is ideal for helping launch a heavy car with a smaller engine with less torque and horsepower.
DOES HAVE SURFACE RUST SO IT NEEDS A LIGHT SKIM
£125.00
FORD MOTORSPORT M-6010-G351 NEW
FORD MOTORSPORT M-6010-G351 block is an iron 9.2" deck non-siamese block with a 4.030" overbore capacity and a CID capacity of 408" To install liners of choice.
It's a 351W design but with 351C main journals, it was a NASCAR block, the oil pan must be modified for 4-bolt main cap clearance
£1500.00
FORD 460 DIVE-6015-A2B
£250
Edelbrock Victor Jr. Intake Manifolds #2981 351W NEW
Intake Manifold, Victor Jr., Single Plane, Aluminum, Natural, Square Bore, Ford, 351W
Low-profile, single-plane Victor Jr. intake manifolds from Edelbrock are very versatile and can be used for drag racing and Oval Track competition, as well as for street applications. Power bands range from 3,500 to 7,000 rpm, on up to 4,500 to 8,000 rpm. There are applications for small block and big block engines, as well as for 2-barrel and 4-barrel carburetors. Some manifolds accept standard restrictor plates and carb adapters.
£215.00
351 FORD RACING SINGLE PLANE LIGHTWEIGHT C3L NASCAR INTAKE MANIFOLD
M-9424-W351 NEW
£250.00
Edelbrock 60259 - Edelbrock Performer RPM Cylinder Heads For Small Block Ford NEW
Performer RPM Aluminum Cylinder Heads - Complete
Designed for non-emissions 289, 302, and 351-Windsor Ford engines, these direct bolt-on heads deliver maximum performance in the 1500-6500 rpm range for all high performance street applications. Will not accept rail rockers.
Note: Aftermarket 289/302 heads including Brodix, Edelbrock, Ford Motorsport and World Products with 1/2'' bolt hole diameters (block is 7/16'' bolt hole), except 397-M-6049-P303 (''P'' style head). Require 350-9680 inserts with 350-8552 head bolt or 350-9680 insert with 070-154-3601. If head studs are desired use 070-154-4005 (includes inserts).
£1100.00
BARRY GRANT TUNE HOLLEY 850 CFM DOUBLE PUMPER NEW
Very trick brand new carb £325.00
CALL 07796962101
