15th June 2010, 18:58
exterior mirrors
hi guys, just brought some cool looking mirrors for my speedster kit,dont want to take a chance on using them for my iva test , so am going to fit a set of cheap and cheerful that will definetly pass,any advice on a supplyer , or have any of you got an old set that have already passed you dont require, looks dont matter,also anti theft /immobiliser,what are you using,i was thinking of a electronic immobiliser, but you require documentary evidence?is this right,any advice always helpful, cheers guys
16th June 2010, 07:22
Can't help on the mirrors, but my Cabrio passed IVA with the Sierra steering column lock as the anti-theft device.
17th June 2010, 09:14
I don't have a steering column lock. I just used a battery master switch. This was acceoted as the immobaliser.
19th June 2010, 07:31
I used the BMW immobiliser EWS 3.3, which passed IVA OK as the requirement for documentation had been suspended at the time (last Dec). I believe that it has now come back into force though. I did have a letter from an auto electrician just in case, but this wouldn't have been enough as it has to be from an approved installer.
The mirrors is mainly about being able to fold back under pressure, no sharp edges and of course the visibility tests.
Tim
22nd June 2010, 07:33
Robin,
You woz lucky! IVA section 13A specifically excludes a battery master switch!
Chris
22nd June 2010, 08:35
Nah, he was just early - Robin went through SVA...
15th July 2010, 19:08
reguarding exterior mirrors
hi,going to go with the same exterior mirrors as you have ,rang the company you recommended,they have the same style mirror but only with a convex glass,is this still passable for the iva,cheers
15th July 2010, 21:22
Mine are convex glass, and passed with no probs.
Don't forget that you will need to add some rubber around the edge of the mirror to ensure it complies with radius checks, and cover the nut on the front of the mirror with a plastic nut cap (you'll have to use some hot glue to keep it on - as the standard cover sizes are either slightly too big, or way to small)
