Last weekend I removed the old bushings using a combination of blow torch, hammer, pliers and swearing. I happily slapped on some POR15 and planned to push the bushings in this weekend.
I have now looked in detail at the eye holes in one of the suspension rods. Most appear to have a metal insert inside the eye hole (1st picture) but one doesn't (2nd picture). There are inserts in both ends of the other identical suspension rod.
The 3rd picture shows the replacement bushing which has no external metal sleeve although there is a metal tube to go through the middle. It really doesn't look like it will fit with the metal sleeve in place.
The question is, should I remove all the metal inserts or should I add one where it is missing?
