Old 5th April 2012, 09:16
Charman.tech's Avatar
I was thinking sound proofing rather than rust proofing. I remember as a kid going in an uncles plastic kit car and almost feeling every stone chipping hitting the bottom of the tub.
Charman.tech - Quick question on remounting the body. When I took mine off there were bits and pieces of rubber strip on top of the chassis. I guess they were to stop the body rubbing about too much. Are they meant to be on every bit of the chassis? Will cut up strips of inner tube suffice?
I think they are meant to be on any part of the body touching the chassis we will have to do ours at the end, You can I think but purpose made rubber strips for this.
I image they are there to seal the car to the chassis but more importantly to cut down on vibration and structure Bourne sound transmittance.
Old 5th April 2012, 11:10
volospian volospian is offline
volospian is on a distinguished road
Originally Posted by Charman.tech View Post
You gota go G46 after the sketch you did! what else do you have in mind?
Only whether to keep it a "standard" scimitar or not. No other contenders!
