5th August 2013, 07:28
I really like the penultimate pic. It looks ready to go. Nice job.
5th August 2013, 07:40
Agree with comments above, black chassis and frame looks classy.
Moon rover stage looks good to go!
21st August 2013, 11:05
Looking bl**dy gorgeous. Getting lots of ideas for my Spyder build.
Keep it up.
Slarti
21st August 2013, 14:30
hi tony could you give me the meurment of the floor pan the rear one width and length +/_ 5 m/m sorry to be a pain going to make my seats this week thay may end up in the skip ta dave r
22nd August 2013, 12:28
i'd also be interested in those measurements, and also whether the "drop" at the rear takes the low bit lower than the bottom of the centre chassis rail, and if so by how much?
22nd August 2013, 20:21
And this is what the rear ones look like in situ...
23rd August 2013, 11:47
hi T ta for info dave r
24th August 2013, 22:27
Ditto
X2
28th August 2013, 09:38
Good job, congratulations !
2nd September 2013, 19:05
The body arrived today...
Fits well, after cutting the slots for the rear outriggers and steering column. even the wheel arches seemed to line up.
but... my eagerness to get things done before the body arrived may have backfired a little as the battery access is now non-existent and the steering column needs to be about 50mm longer
Anyway, I will have a go at some of these bits over the next few days, and hopefully if the weather stays dry at the weekend, I might get it all bonded on!
2nd September 2013, 19:37
I am envious have you cut the front springs looking really good dave r
2nd September 2013, 19:48
Wow, it's a beast already. I like how the wheel fill up the arches. Agresive nose. I like it.
Michiel
3rd September 2013, 10:25
yes, I cut the front springs down by 70mm and not lowered the rear at all yet. I might get the 25mm lowering block for the rear - that should be enough..
T
3rd September 2013, 11:54
I'm fond of the Miglia body, maybe for another project because I've to finish first my SAMMIO CHEVAUX !
Your built is very well done congratulations, don't hesitate to put pictures all over the construction witch help others builders !
3rd September 2013, 12:20
"seemed to line up" i'm sorry, that confuses me!
3rd September 2013, 20:06
Springs
Tony. You say you cut the springs ... ? not got round to that on my Sammio build yet, but was thinking of getting early Spitfire ones ..... is there any particular advantage in just cutting ...must have to be pretty acurate ... intrigued. let me know
BTW ... phoned your brother this evening & will drop the hub puller back soon. Hope we can meet up for a beer.
Slarti
4th September 2013, 15:57
Glad it fits . no reason why not looking good .. Keep up the great work..
4th September 2013, 18:28
+1
Jokes aside, it really looks good.
Good luck with the rest of the build, Paul.
31st October 2013, 13:56
hi have been looking at your biuld very nice it is.....i was interested about your brake pedal and servo choice? bmw? how did you find it?is it a 3 series bm? would you mind if i used it????
thanks nice job ikon 246
clive
