30th May 2015, 12:50
The cars looking great scottie and good luck with the MOT but wont it need seats?!...
30th May 2015, 18:58
Yes it will Danny, but I can't put them in until I've got the windscreen glass in, or I'll be treading all over them, nor can I put the doors on until the screens in either, 'cos they get in the way, so its a set sequence I have to follow.
30th May 2015, 20:43
Saturday
Today I got the boot lid back on and fitted the lock.
It now opens from the hidden pull behind the seat and locks as it should.
I did some more mopping which I really enjoy for some reason!
I'll have to be careful not to get carried away and mop through the paint.
Generally, the paintwork is not too bad, but there are lots of small imperfections where the paint has reacted, where insects have sat in it, one or two tiny bubbles that I have missed, and so on, but from 10 feet away, it looks okay.
It certainly has a good shine on it, imperfections or not, and I suppose that's the main thing.
I came under a lot of pressure today from friends and family to put the final wheels on the car, so I gave in and did it.
The results were quite amazing, so I took some pictures.
I have always believed that the wheels "make the car" and in this case that is very true, it seems to have transformed it, and it now looks very much like I wanted it to.
I would have got the screen in today but my "help" let me down and did not arrive, and I don't want to tackle the job alone in case I damage the bodywork.
So its screen, doors, seats, belts and one or two smally jobs, (if we don't count making a roof) and its about there.
Here are the pics I took today with the wheels on:
[IMG] [/IMG]
[IMG] [/IMG]
[IMG] [/IMG]
[IMG] [/IMG]
[IMG] [/IMG]
30th May 2015, 20:45
PS. If you read this Chris, I still need my perspex headlight covers
you promised me at Stoneleigh!
30th May 2015, 20:46
Just "wow" !!!
30th May 2015, 20:59
.....but from 10 feet away, it looks okay.
It looks okay? It looks bloody fantastic!
I was never a huge fan of the XKSS and always thought that the D-type was far prettier but what you have built is stunning, well done!
30th May 2015, 21:07
I agree with you Gaz, all the XKSS's were made from short-nose D Types, and all looked a but "pug nosed" but Chris made the A352 from a long-nose D Type, so when I first saw his shell, I could see the potential to create a real one-off XKSS that would be more to my taste.
Just wait until all the seats and belts are in and the doors are on....!!
30th May 2015, 22:18
Wow, that looks great Scottie. Can't wait to see it with the seats and doors back on.
Good luck with the MOT, then off to Le Mans, eh?
31st May 2015, 09:22
Top work, now waiting for 'Scottie on the road' thread....
31st May 2015, 09:30
Scottie finished in time for Stoneleigh shocker!!!!!!!!!!!
31st May 2015, 11:29
well done Scottie, brilliant looking car, take a bow.
31st May 2015, 12:05
Thanks, IanA, Gaz, y cymro, WCA and Thurcroft flyer!
I am on a roller coaster of emotions right now as each new crisis looms up to put a stop to me getting on the road, let me explain:
yesterday the water temp gauge stopped working, and I banged my knuckles on the dash, as the wheel was too close.
These two things really got me down and depressed me.
However this morning I went out and after much fiddling with mirrors, effing and blinding etc, I managed to put back on the rear of the gauge the connection that I had knocked off with fitting hassle.
I then went upside down in the drivers foot-well, and again, after much of the aforementioned, got the steering column extended to the right length.
So far so good, then as I went to drive the car outside, on depressing the clutch pedal, I noticed it went down about an inch or two before I felt any pressure, and had to push it to the metal to get the clutch to operate correctly.
This really pissed me off, and laid me low, so my question to the experts who know all about Triumphs is: do I need a new master cylinder?
I kind of half expect I do, but would like an expert opinion, and I know a lot of you out there WILL know!
So please give me your thoughts, as I am still not ready for the elusive Mot yet! And the new work just keeps on coming......
31st May 2015, 12:42
Now don't get carried away WCA! Its NOT finished, or even Mot'd yet. (And no roof either)
I should have said in my earlier post that the fluid level is ok in the Master cylinder.
And boy, am I pleased that I cut that access hatch in the wing!!
Without that I would have been in serious trouble.
[IMG] [/IMG]
[IMG] [/IMG]
31st May 2015, 13:36
One bit of foresight is SO much more valuable than loads of hindsight!
Can't help with the clutch but good luck
31st May 2015, 14:01
Scottie - Sorry I can't help you with the clutch, as I haven't managed to get my own one working properly yet.
But the wheels do look great.
31st May 2015, 14:03
... on depressing the clutch pedal, I noticed it went down about an inch or two before I felt any pressure, and had to push it to the metal to get the clutch to operate correctly....
Look for any leaks first.
Try bleeding the clutch circuit next.
If it persists- replace the clutch master cylinder seals- cheapest first option.
Then replace the clutch slave cylinder.
Then replace the clutch master cylinder.
If none of that works, I'll take the car off your hands for a few dozen Curly Wurlies.
Forgot- is there any scope on the Triumph for the clutch release arm not to engage with the release bearing properly?
Reason: Remembered my first rebuild.
31st May 2015, 14:13
The car looks stunning Scottie. good luck with the clutch are you sure it's not the slave cylinder? also the pivots on the leaver arm thrust bearing can seize up giving reduced travel?
31st May 2015, 14:33
Bleedin' Clutch
Even a tiny tiny leak will let enough air in to make you lose your pedal, so don't pay any attention to the apparent full level in the master cylinder.
If it pumps up it's definitely a leak. Luckily, unlike the brakes , there are only four possibilities. Past the seal on either cylinder; peel rubbers back and check, or from the union at each end of the hose; wipe with finger underneath.
Good Luck.
p.s. My internetting is now performed to the sound of this You Tube clip played over and over through surround sound and sub-woofer
https://www.youtube.com/watch?v=Vfcf8UqMNiw
31st May 2015, 14:50
In my experience oldish hyraulics don't like being left unused for even a few weeks.
Any suspended solids sink to the lowest point and gum up the seals.
I would buy 5 litres of brake fluid and give the brakes and clutch a really good bleed.
31st May 2015, 14:59
Scottie, just spotted this, my bet on your clutch will be on the master cylinder seals.
However, despite the foresight of the access hatch, it won't be easy to remove/replace the clutch master cylinder, I would NOT recommend replacing the seals. In my experience replacing brake/clutch seals has been not worth the trouble. OK may be cheaper but when access is such a bitch I would go for a one time fix of replacement, whichI have just done myself because although my clutch was working perfectly, it was weeping fluid down the bulkhead, a sure sign of impending failure.
With the Triumph master cylinder being made of aluminium, combined with a steel piston the result is usually scoring and corrosion of the bore, replacing the rubber seals won't fix that.
Probably a good idea to look at the slave cylinder first but if the fluid level is OK, then I would suspect the fluid is bypassing the master cylinder piston, or it's sucking air on the up-stroke.
This is a byproduct of the car being relatively inactive over a long period, not just during a build, it can happen whenever a car is laid up for long periods, rubber can go soft, or hard, neither change is good.
