2nd June 2014, 23:19
[ATTACH][ATTACH]1334[ATTACH]1334[ATTACH] image.jpg[/ATTACH][/ATTACH][/ATTACH][/ATTACH][ATTACH][/ATTACH][ATTACH][/ATTACH]just trying to remember how to post photos
19th June 2014, 16:55
19th June 2014, 16:58
19th June 2014, 17:00
19th June 2014, 17:02
19th June 2014, 17:04
19th June 2014, 17:11
body and frame arrive happy days , but lots of work[ATTACH] image.jpg[/ATTACH]
19th June 2014, 17:12
19th June 2014, 17:13
19th June 2014, 17:15
19th June 2014, 17:16
Your rolling chassis looks very nice.
Good luck with the rest of the build, Paul.
19th June 2014, 17:33
trying body and frame on for initial fit, frame not sat down correctly, but not too far off image.jpg
19th June 2014, 17:35
19th June 2014, 20:50
Keep the photos coming, i'd like to see how the floorpans go in and how you bond it all together.
20th June 2014, 05:51
I'm loving the job you've done on the chassis, its certainly giving me some ideas of what to aim for with mine!
Out of interest, have you gone for a red gel coat on your body?
20th June 2014, 08:23
Nice to see - and will be interesting to see how the red gel coat pans out - or will you spray as well?
20th June 2014, 09:38
Have you / do you have to lower the radiator with this Miglia kit?
I know i did on the Sammio and TBH it's not a problem, but if i don't have to then that will be great!
20th June 2014, 09:50
Isn't it in the comprehensive build manual?
20th June 2014, 12:13
I have gone with a red gel coat as i want to mot test and get on the road before I have it painted, thought it would just keep it all, one colour, plus I will be spraying it red any way in the end. the radiator as remained in the original mounting place as on the vitesse, but the body frame also fits to these mounts, so I advise you not to fit your rad to vehicle until you sit your frame on. I then had to trim the rad mounts just to get it to sit flush. I sat the frame on when it was delivered just to be able to get it all in garage, that is why the body looks high at the front in the photos, this will sit lower down over the front wheels now I have fastened the frame on correctly, and rad is now back on.
