19th January 2018, 12:14
Death or Glory! Nick attempts to work under the car
The suspension has gone clunky over bumps and ruts with nasty feedback through the steering wheel. This, combined with the MOT man mentioning some under body corrosion has persuaded me to stick the car on axle stands and do some work.
I will try to do fairly regular updates on progress, even if it is only slight progress, just so you know I haven't been crushed beneath the car.
There will be lots of pictures as people like pictures.
First get the kit you need
20180118_121402 by WCA!, on Flickr
Look how much space I have to work in
20180119_114934 by WCA!, on Flickr
Look at all the crap piled up to make that space
20180119_114947 by WCA!, on Flickr
Get the car in the garage
20180119_115133 by WCA!, on Flickr
Realise I can't get the jack under the front of the car
20180119_115926 by WCA!, on Flickr
Drive up the ramp to raise the front a bit
20180119_121702 by WCA!, on Flickr
Now the jack fits (and I have also spotted a leak)
20180119_121848 by WCA!, on Flickr
Use the wooden block to get a bit more height
20180119_122528 by WCA!, on Flickr
Round to the back and jack positioned just in front of the rear diff
20180119_124159 by WCA!, on Flickr
Once I had both ends raised I had to jack the front of the car up a bit more and re-position the axle stands as they had started leaning backwards when I raised the rear of the car. All raised and level now.
20180119_125947 by WCA!, on Flickr
And the garage door shuts with millimetres to spare
20180119_130122 by WCA!, on Flickr
Now I guess I ought to start doing something as you can see the corrosion.
19th January 2018, 12:38
Corrosion
Great to see someone do a thread on treating a Z3. We will all have to deal with this sooner or later. Take plenty of pics,
20th January 2018, 19:41
Thanks for this useful thread, Nick.
I have all of those parts in my round tuit box.
I'll be doing mine al fresco on the gravel drive once the weather improves.
My tips:
Penetrating fluid- 50% acetone + 50% ATF sounds like the best.
Gloves- "rigger" gloves from Poundland
Axle stands- cut from railway sleepers - they don't collapse.
Undercar work- I'd really like one of those tipping rigs.
Rust killer- Bilthamber Hydrate. Can be painted over when dry.
19th January 2018, 13:19
The first task went a lot easier than I was expecting so a quick update already.
iu am planning on replacing both lower control arms as mine are pretty cruddy and I suspect the clucks are coming from worn ball joints.
20180119_132411 by WCA!, on Flickr
Before that though I decided to removed the front anti roll bar (ARB) so that I can clean it up and treat with POR15 to hopefully slow the return of the rust.
As I will be replacing the ARB links as well it seemed easier to just undo the 16mm bolt that held that to the control arm.
20180119_132924 by WCA!, on Flickr
Amazingly it unbolted with little or no swearing so I move onto the 14mm bolts holding the ARB bushes in place and again, they simply undid. What do these crazy Germans use to stop their nuts from sticking?
20180119_132507 by WCA!, on Flickr
Within 5 minutes of starting the ARB was free from the car and I was feeling happy.
20180119_133714 by WCA!, on Flickr
The bushes would need rteplacing and the holding brackets cleaning
20180119_135014 by WCA!, on Flickr
There are lots of different sizes for the front ARB apparently so measure carefully before ordering the replacement bushes.
Now I need to work out how the get the ARB Drop link off the ARB as when I turn the nut, the whole thing just turns within the ball joint. As it is being replaced I suspect some violence may be used.
Next I try to remove the old lower control arms. I shall be using this YouTube video as my guide* : https://www.youtube.com/watch?v=4iSrW61Zbz4
* mainly for the music and cool hair style
19th January 2018, 15:31
No violence was needed. Just a 16mm spanner to hold the flat spots on the side of the link.
20180119_143109 by WCA!, on Flickr
Easier to see when it is removed of course.
20180119_143347 by WCA!, on Flickr
19th January 2018, 15:55
Removing the control arm looked easy in the video and for me, one of them was (relatively) easy, the other is currently still in place after being strongly sworn at but still removing to budge.
First, locate the nut above the ball joint at the wheel end.
20180119_143546 by WCA!, on Flickr
Loosen this as much as you can but it will soon hit a bit of the suspension. The best way I found to loosen this was drown in WD40 and leave for 20 minutes. Put a spanner on it and then hit the spanned repeatedly to gradually shock it loose. It is a really tight space and you can only locate the spanner against one pair of faces on the nut. The first one I tried by just pushing the spanner has slightly rounded those two faces on the nut so that control arm is currently still in place.
20180119_154039 by WCA!, on Flickr
Once the nut is as undone as you can make it you need a ball joint splitter. If you don't have one then buy one for about £10 at Halfords or similar. Smack it repeatedly with a hammer until suddenly it pops loose and the control arm drops and you can undo the nut from the rest of the thread. This also has a 16mm flat spot to stop it from just spinning. It is worth remembering this rather than just spinning the nut pointlessly for about 10 minute (yes, I did).
20180119_153954 by WCA!, on Flickr
Next find the 22m nut above the central ball joint. This is easier to point at than to actually reach with a spanner
20180119_144411 by WCA!, on Flickr
When I did get a spanner on it I couldn't swing the hammer enough to use the shock wrench technique so was reduced to just adding extra leverage. A small socket on the end of a socket extension bar gave just enough extra leverage to loosen the nut. Once the stick was unstuck I could just the spanner on its own to turn the nut but at no point was it finger tight like on some YouTube videos.
20180119_160107 by WCA!, on Flickr
Beforer trying to break the middle ball joint, locate the rear bush mounting bracket. These bolts are easy to get at and I loosened them both a few turns but left them in place while I tried to break the ball joint. When the ball joint gave up the control arm dropped suddenly but the two loose bolts help it in place just a few centimetres from my face. I was releived I though to leave the bolts in place
20180119_161535 by WCA!, on Flickr
Having moved my face I undid the bolts fully and the control arm fell smoothly to the ground.
Now to compare the old and new swing arms. Well the new one was black and clean instead of silver and dirty which was a start but the surprise came when I wiggled the bolts stick up out of the ball joints. On the old one they wobbled freely whereas with the new one they were absolutely stiff. The old ones were definitely knackered.
I will try to post a link to a video showing the difference. Please can someone click on the picture and see if they get taken to the video and let me know if it has worked.
ControlArms by WCA!, on Flickr
19th January 2018, 18:17
Summary of lessons learned following contemplation in the sauna with a bottle of wine:
1) You know that crap piled up around the garage to make room for the car? Stack it well. I have a VERY sore head after being hit by a falling chromed cocktail stool.
2) Wear safety goggles. All that rust, dirt and crap on the bits you remove falls straight into your eyes until you have it removed.
3) Find some magic gloves that don't tear, don't get in the way of what you are doing and stop all the little cuts and scratches on you fingers.
4) Don't fully unbolt the easy last two bolts at the back of the control arm before breaking the ball joints.
5) Speaking of ball joints, once you have used the ball breaker on them you need a 16mm spanner to undo them.
Of these wise words I only used number 4 today. Number 5 occurred after 10 minutes.
Anyway, Still alive and more tomorrow
19th January 2018, 21:18
Video works thanks. I am sure this thread will be of use to many.
20th January 2018, 08:29
Great thread, very useful guide that I'm sure a lot of people will find useful (and entertaining)
Your build up of 'things' in your garage looks surprising similar to mine (except my garage is a single )
20th January 2018, 12:53
1. Has to be a contender for quote of the year already.
3. Marigolds
20th January 2018, 09:05
The plan for today it to get the other control arm off and then as many hours as I can stand with a wire brush cleaning stuff up.
Probably less exciting photos but I will try to capture the Before and After as I go along.
I have hit a small snag so I thought I would post a quick update while I google the solution.
First, some useful bits when doing this. A nice warm wool carpet on the cold concrete garage floor and a couple of LED lamps. The lamps were a couple of quid from B&Q or similar and can be positioned around the engine bay so they cast light on what you are working on instead of a torch with a norrow beam simply casting shadows everywhere.
20180120_103138 by WCA!, on Flickr
This morning the 22mm nut holding the middle ball joint on came loose fairly easy. Watch out for the two studs that held the ARB bush in place as the can give a nasty scratch. Also note that with the ARB in place it would be much more difficult to get at the bolt so it looks like removing it first was the right thing to do.
20180120_101903 by WCA!, on Flickr
Feeling confident and after slightly loosening the two bolts holding the rear bushing I had another look at the 18mm nut by the wheel. Why do all the guys on YouTube have so much more space to work? I was totally blocked by that bracket and was in serious danger of totally rounding what remained of the bolt so I stopped and assessed the situation.
20180120_101231 by WCA!, on Flickr
I had a piece of metal bracket in my car that the other guys didn't. Why?
I had fitted after market adjustable coil overs and they were blocking proper access to the nut. Now I am going back to the garage to disconnect the coil overs and hopefully get proper access. I might we do this on the other side as well as it will made the wire brushing around tghe brake a whole heap easier.
20180120_101258 by WCA!, on Flickr
20th January 2018, 11:09
I tried just removing the lower bolts and loosening the top bolt so I could move the hub a bit
20180120_112139 by WCA!, on Flickr
This gave me a better view of the nut that I was gradually rounding off but still not enough room to work
20180120_112223 by WCA!, on Flickr
Releasing the top bolt let the whole hub drop supported just by the ABS wire and the brake hose. A quick grab for a spare axle stand saved the day! I now had lots of room to work. It still wasn't easy but at least it was not possible.
20180120_113912 by WCA!, on Flickr
I have now taken a break before continuing with the ball joint breaker to soak my thumb joint in iced water. Yes, I hit just smack my thumb joint with a lump hammer. Ow!
20th January 2018, 11:23
When working on rusty suspension nuts and bolts I would suggest that you only use 6 sided sockets, they won't slip like 12 sided sockets, once you have rounded a couple of nuts off you will realise why.
A bit of WD40 and a quick wire brush on the visible threads makes the job much easier.
20th January 2018, 11:38
The position of the nut before I dropped the whole hub meant an open spanner was the only option unfortunately. I agree with the 6 sided principle though.
I am thinking of sticking copper slip on the contact points and bolts when I put it back together. Any thoughts on that?
20th January 2018, 11:52
Copperslip is a very good idea for suspension and brakes.
I did put it on bonnet releases but found it dried out so not so good.
With suspension parts, if you can get a six sided socket on, use a breaker bar rather than a ratchet as you can damage a ratchet. A decent extension bar is always very useful, not much you can't undo with a 6' scaffold pipe on the end.
20th January 2018, 14:47
I can confirm that cleaning the rust and crap off the bottom of a car is not something you want to do. you want to pay someone else to do it. There is no fun, pleasure or joy in doing this. Anyway, I went through this to show you why you don't want to.
First, get a selection of wire wheels that will fit in your hand drill. I started using a battery drill but even using an 18v Panasonic drill, the corded version was so much better and the cord didn't really get in the way when working. The ones on the right were good for most surfaces. The bright copper wheels were best for cleaning narrow pipes as you could get them to clean all around the pipes and tubes. The skinny round on on the left was okay for small spaces.
20180120_131436 by WCA!, on Flickr
Here is a 'before' of the hub
20180120_131656 by WCA!, on Flickr
A close up of my finger tip and the cracking rusty surface of the metal.
20180120_131702 by WCA!, on Flickr
Breathing mask and goggles before starting. Believe me, you really, really want to be wearing these or preferably one of those fully enclosed white space suits.
20180120_131847 by WCA!, on Flickr
The wire brush in action. Be careful not to brush the rubber bits as they disappear quicker than the rust.
20180120_132027 by WCA!, on Flickr
I am not sure of the benefits of removing rust from the brake discs but they were easy to get at so I gave them a quick once over.
20180120_132415 by WCA!, on Flickr
A bit less scabby now.
20180120_132619 by WCA!, on Flickr
The crusty flaky surface is now smoother. Still some rust but I plan to paint it all with POR15 which is fine only small amounts of rust as long as you remove the flaky bits.
20180120_133316 by WCA!, on Flickr
Having cleaned up the drivers side hub I decided to start at the front of the car and work my way back underneath it. Lots of pictures, mainly for my own record but basically you are stuck in a cramped space in a cloud of rusty dust with a drill whirring in front of your face. No pleasure at all.
20180120_140601 by WCA!, on Flickr
20180120_141151 by WCA!, on Flickr
20180120_141223 by WCA!, on Flickr
20180120_141611 by WCA!, on Flickr
20180120_141642 by WCA!, on Flickr
20180120_142339 by WCA!, on Flickr
20180120_142955 by WCA!, on Flickr
20180120_143846 by WCA!, on Flickr
This got me about half way along the car and I decided to call it a day. I know it is an early finish but I am not being paid so there is no rush.
And this is what my nice woollen carpet looked like after all that cleaning
20180120_151118 by WCA!, on Flickr
I shook the carpet out but needed to clear out all the dust. Google suggests compressed air so I opened the garage door and generated some compressed air in my own special way.
20180120_151306 by WCA!, on Flickr
20th January 2018, 18:20
When using the wire brushes, use the brass cup type in an angle grinder, far more effective than a drill. You must wear goggles as some of the strands come loose.
The brass type doesn't damage the metal and can also be used as a rapid way of removing paint as well as rust.
Before painting the parts I would suggest brushing on rust converter, this kills the rust, then wash it off and paint. Loads on eBay including some in aerosols so you can convert rust that you can't get too, not ideal but better than nothing.
Last picture, is that one of those Black & Decker anal probes?
20th January 2018, 18:43
I thought the angle grinder would be too fierce and hard to control in the limited space.
I plan on using POR15 Metal Prep, wash it down and then silver POR15 before top coating it in gloss black.
POR15 will degrade in UV so the top coat is important.
The washing off of the metal prep is worrying me as I am stuck inside a garage. Perhaps wash off and leave an air heater on overnight.
I still need to get the back of the car prepped before that which is probably tomorrow taken care of. I will try the angle grinder and wire wheel on the ARB and use that for the first test of Metal prep, POR15 and top coat as that is free standing and easy to work on. That might help me plan the car underbody painting.
21st January 2018, 09:43
Weather isn't great and it looks like it is raining for the rest of the day (maybe forever)
Weather by WCA!, on Flickr
I know I have the luxury of a garage but today I was planning on de-rusting the back end of the car which would be easier with the garage door to be open. I will spend some time walking around the garage, sucking my teeth and planning before I decide if I will fre up the wire wheel again. I must admit I am not looking forward to another session under the car after yesterdays.
Updates may follow
21st January 2018, 10:01
And I thought the cold weather was part of your plan........ Any bashes to the knuckles or similar have little effect because the hand is so cold
