29th May 2018, 11:46
MX250C build
Hi all, I need some help with the build I have just started (had the kit and car in the garage for a year and just getting around to starting after moving home) This is my first time building a kit so just a little nervous about what I should and shouldn't do!
I've stripped the front end, attached the fibreglass wing supports, etc. but I have a couple of issues. For the life of me I cannot get the front end to marry up with the two under wing bolts near the drivers door (other side seems fine). There is a bolt on a mount half way between the top and bottom of the inner wing (near the door) should I be using this or just get rid of it?
Second issue, bought the mini head light kits as suggested in the parts guide but the bowls behind the lights are too big and hit the corners of the car frame. Do I cut these parts of the frame out, bash them in with a hammer or cut the backs of the bowls off?
Finally does anyone who has built a 250C have any build tips they could send me to make my life easier!
Any help or suggestions would be greatly appreciated. Thanks Terry
29th May 2018, 16:21
Originally Posted by terryg
Hi all, I need some help with the build I have just started ...Finally does anyone who has built a 250C have any build tips they could send me to make my life easier!Any help or suggestions would be greatly appreciated. Thanks Terry
Welcome and good luck!!!
Forum search is your friend here. There are a number of MX250 build stories here (and some stunning results to inspire you).
The second issue is a common one and has definitely been covered a number of times.
I don't recall anything about the first one but once you've found the threads and the builders, they'll be happy to share their experiences.
29th May 2018, 18:10
Hi, welcome, I’ve built two mx250 c ‘s a mk1 and a mk2 , so feel free to ask.
Ref the bowls, I cut the back off, it’s only plastic and doesn’t serve much purpose, I little tap with the hammer on the metal frame was also useful.
Where are you based?
My thread (one of them) is “I thought it was finished” the other is “Adams 250c”
Good luck
29th May 2018, 18:40
Hi - welcome and good luck. This site is great for finding advice and pictures. Make a note of the two mentioned so you can always find them plus any others you find.
It is sometimes worth posting a question on those threads or a link to the new thread you have created. That way the original people will see their thread on the first page and their curiosity/vanity will prevent them from not responding.
29th May 2018, 18:50
Hi there, did you remove the old bonnet hinges? When i built mine I had to grind them off as they wouldn't unbolt and were in the way.
If you pm me your email or phone no. I can offer you advise as you need it
30th May 2018, 11:17
help with MX250C build
Thanks for the advice! Great idea. Regards Terry
29th May 2018, 22:48
Good luck
Thanks for the information, the bowls I have are metal but I guess it's just the same, will definitely try a little fettling the frame with a hammer! Thanks for the threads as well, I'll go through them.
Cheers Terry
30th May 2018, 04:48
Welcome to the forum!
Welcome Terry, sounds like you have plenty of inspiration reading in the threads to get on with already shared, the one thing you will find is there is always an answer or a friendly ear or two ready to assist when it gets a bit challenging.
All the best, look forward to watching your thread with interest whilst I am building my Italia 275GTB. Keep posting! Cheers Mark.
30th May 2018, 12:05
Hi Mark, is that Mark Blyth who I've just shipped a 275GTB to?
30th May 2018, 12:18
First pictures
31st May 2018, 03:16
The very same sir! You can find my thread in the Old No 7 part of the forum.
For info the vessel is in the Red Sea heading for Jeddah, just the Somalian pirates to get past and it is almost here! Cheers.
