12th November 2012, 20:06
Originally Posted by Cat7
Chris n the following
15x7, 4x100 PCD, ET20
15x8, 4x100 PCD, ET20
15x8, 4x100 PCD, ET5
was thinking of 15x8 on rear and 15x7 on the front. Do you think that would work?
Nev
Yes. Plus a 1" spacer on the rear.
CHRIS, great list of links, thanks!
12th November 2012, 20:10
Nick, once again doing my work for me while I take my "eye off the ball" Thank you. Correct as always. The list of links is not complete, but useful as a starting point.
12th November 2012, 20:22
Just filling in time while you read the Sammie forum
I think the mirror link may be for the wrong mirror?
12th November 2012, 20:25
spacer
Guys,
would that be the ET20 offset requiring the 1" spacer?
being a tad thick me feels...
12th November 2012, 20:29
Guys,
Nick?
Mirror link now changed to Bullet ones, the other mirrors are the ones fitted to the convertible we built....
12th November 2012, 20:43
I think you simply go for the minimum offset.
Eg I have 6.5j rims with a 43ET, but a 20mm spacer on the front, which brings the ET down to 23mm.
If you have 8" rims that will be about 3/4 inch wider (20mm) each side than yr existing 6" rims. I would not go wider or less offset as it may look good but you may get bump steer and there may be clearance probs ob full lock.
12th November 2012, 20:53
If you have 8" rims that will be about an inch wider each side than yr existing 6" rims. I would not go wider or less offset as it may look good but you may get bump steer and there may be clearance probs ob full lock.
Sorry, I was just looking at wheels on ebay.......
Nick is right about the front, I would go with the 15x7 ET20. The rear needs to be the 15x8, 4x100 PCD, ET5 with a 25 mm spacer. But I will double check for you, before you go ahead and order anything.
This is a great link: http://www.gtsparkplugs.com/WheelOffsetCalc.html
16th November 2012, 15:12
Pre GRP work
Been keeping myself busy in the garage while I wait to go and see Chris on the 23rd to sort out the kit. Decided to strip down the rear suspension, deal with any worn parts, Brake disc's Pads etc . Glad I did in the end as the rear hub to wishbone bolt was bent and now awaiting new coilovers and discs & Pads. So now coating the suspension arms and decided to treat any surface rust and cold galvanize everything, followed by a good dosage of underseal. Result below
16th November 2012, 17:45
Great work Nev, you will have a fully sorted base car by the time you get the kit home. See you on the 23rd
16th November 2012, 18:05
23rd
Hope the kettle is going to be at the ready , looking forward to meeting up to chat about all the stuff i am out of practice at... i.e. working with GRP.
By the way have you got any pic's of how the rear section attaches to the tub, especially by the doors?
Nev
16th November 2012, 21:35
Sorry Nev I have fallen behind on the Build Manual but take a look at the "Convertible MX250" and "New Version of MX250 based of Mk2 MX5 " treads whilst I catch up!
17th November 2012, 20:58
That looks really good. Are they standard shocks/springs?
You also seem to have a nice working height. Whats the car up on??
17th November 2012, 21:13
Ramps
Seanick,
The car is on drive on ramps that can be elavated once the car is on.
Here
At the moment have refitted the Bilsteins and standard springs, but ordering some coil overs to give the option of altering the ride height for the flexability once i have the new wheels and the body on.
Ramps were from a company called Levo Artis
link below
http://www.levo-artis.com/contact-levo-artis.html
17th November 2012, 21:15
Colour choice
Any thoughts on this colour combo?
17th November 2012, 21:25
I like that, it would work on the MX if it was stickered up in the same fashion
Suspension is looking super clean, good work.
17th November 2012, 21:34
Err , well, you would defo get noticed! You had better drive nicely!!
17th November 2012, 22:26
That looks awesome!!!
Any chance of the 'Aston Martin' Front with the soft top in yellow???
This is my plan for my build :-D
18th November 2012, 15:16
I prefer the original Gulf light blue. But If you get it to look like that picture you will have to give yourself more time to go anywhere as it'll stop the traffic.
