Jones - Just looking at those flames makes me feel warmer.
As I look back, I think this has been the longest run of wet weather I've had this Winter.
Because I was still able to get some work done even when others were snowed in.
So overall, I've got to be happy with just how many jobs I have managed to tick off.
scimjim - I think it is fair to say I know more about air flow today than I did last week.
I also think the new grille mesh is going to give the car a more traditional look.
A Mixed Day - Part 1:
Lots of other things to do today, but with a decent weather forecast, I really wanted to squeeze a few car jobs in too.
But rather than follow a strict time line, I've grouped the jobs together for convenience.
I quickly roughed up the area along the main repair between the wing and bonnet.
It is not easy to see in the photos, but I am dealing with a couple of issues:
- Obviously the first is due to the way I re-joined the cut
- But there are also some unrelated "dips" in the bonnet too
This last point links in with the vast amount of filler work that
Swifty has done on his bonnet.
So I added yet another layer of normal body filler.
When the filler was set hard enough I stared sanding it down.
( I am not trying to get the final finish for painting at this stage, just ensure that the overall shape is OK. )
I know the 'after' photos do not look very different to the 'before' ones, but this is actually a big improvement.
Then I sanded some more of the bonnet in preparation for a dusting of etch primer.
As getting the front of the bonnet in one colour would give me a better idea of where I was.
Although the gusts of wind were not making it easy to spray outside.
I am not trying to create a mirror image either side of the bonnet, just a smooth transition over the repair work.
I can see why
Swifty needed to do so much preparation work if he wanted a super smooth finish.
I may simply settle for the
"been into the hay bales a few times" look and live with a smooth, but undulating surface.
I also gave one side of the petrol cap base ring a coat of etch primer too.
Because at some point I want to bond this into position.
I measured the distance the bonnet hinging bolts stick out beyond the nut.
Then I experimented on one of my spare M12 bolts, by removing some of the thread with my angle grinder.
( I fitted 40mm bolts, but also bought 2 x 45mm bolts just in case. )
The plan was to use my new cobalt bits to drill a hole for an "R" clip to go through.
But my drill head has started oscillating slightly, which combined with my accidental application of brute force resulted in this.
What made it worse, was that the remaining drill bits were barely making a dent in the bolt.
So I will put that in the "too difficult" pile for now and come back to it later.
End of Part 1...
