Progress Report:
No real progress to report as I spent the week tidying the house & garden.
Yesterday was perfect day for our BBQ with friends and given today's rain, very lucky too.
My 'thrown together to tidy up' Cordite made it easier for them to understand the project.
I made the mistake of rashly promising it would be on the road by this time next year.
At which point one of my mates opened a "book" on when it would actually be done.
Hopefully the money laid against a 2014 finish will not be collected!!
So the following is more about me 'thinking out loud' and planning my next steps...
Marine Ply Panels Required:
Whilst the body is still on temporarily, I will think about the plywood panels I need to make.
AndyP57 has provided a good example of what is required around the front foot wells.
And most build threads show how the internal cockpit walls are constructed, e.g.
Mr T.
But I have struggled to find clear information on what goes
behind the rear cockpit.
I know
DonnySoutherner has reused an old section of Spitfire bodywork for his Cordite.
But I get the impression that many builders simply leave this rear section "empty" so to speak.
Although I haven't fitted the petrol tank yet, instinctively I think this needs some protection.
Others have storage built in behind the seats, but I wasn't planning to based on KISS principles.
However, some form of rear wheel arch seems like a good idea, but what do I know?
So I'll have a think & play around with some cardboard templates to see what will fit where.
Then I can work out how much marine ply I need to buy and start the process of making the panels.
I will also steal
DonnySoutherner's idea of a sunken battery box made out of ply while I'm at it.
Brakes:
Unbeknown to me, the Cordite was not designed for brake master cylinders from late 1500 Spitfires.
My twin pipe master cylinder is both too tall & too long when compared to the space available.
AndyP57 has resolved this by switching back to the single line system on earlier models.
However, I just can't bring myself to downgrade the braking system of a car that is already 32 years old.
So I need to find a solution that will allow me to retain the existing master cylinder.
One option would be to lower the pedal mounting plate a little & adjust the bulkhead to match.
Interestingly, my Spitfire donor had a recess built into the bulk head for the master cylinder.
So my Cordite bulkhead would need to go "down & back" if that makes sense.
Pros - Leaves the bonnet line as originally intended.
Cons - Some major re-working of parts required.
Another option would be to add some sort of "Wembley Bubble" to raise the bonnet & bulkhead.
Pros - Leaves the internal framework as originally intended.
Cons - May look major league ugly!
I need to get this "right first time" so I will give it more thought before trying to fix it.
Rear Spring Lowering Block:
This is another one of those areas where I am not 100% sure what I am supposed to be doing.
I thought a lowering block was required as a Cordite will weigh a lot less than the donor Spitfire.
However, I see that
AndyP57 is leaving the rear suspension untouched in his demonstrator.
Originally Posted by AndyP57
... I've not put any lowering blocks in mine (And may not do yet) as I want to experiment with wheel sizes to fill the arch, leaving the geometry of the swing spring as it was designed ...
I was never looking for a "low to the ground" racing car stance & had hoped to avoid cutting springs.
As given all the speed bumps around here, I'd run the risk of being "beached" while driving.
Even though I have just thrown the body on, it does look to be riding too high at the moment.
Although I still have to add the petrol tank, seats, wood panel, etc. + driver which will lower it a bit.
So I'll keep an eye on Andy's build and see if his approach works which would make my build easier.
DonnySoutherner's top tip was to sort out the rear suspension
before fixing the frame & body.
So in the short term I will just get on with other parts of my "To Do" list and come back to this later on.
So lots to do and think about, so I'll leave it at that for now.
Dave Cymru -
I now have a 'Wallace & Grommit' sidecar image of my Cordite taking its first sharp turn...
With me & my zip tied frame & body going one way, whilst the engine & rolling chassis goes another!
Mister Towed -
"Beard scratching"?
I need to grow a beard to build a Cordite?
Wow, there really is a lot about this car building process that I just simply didn't know.
Jokes aside, I'm sure the framework will not take too long to sort out, as it seems pretty close already.
