17th June 2016, 20:33
17th June 2016, 22:57
They could be the right fitment but i need steels to fit some of these....
https://www.ebay.co.uk/itm/262459684640
19th June 2016, 14:23
Does anyone know where i can get a set of these chrome headlight rings from with the visor bit at the top? Im asuming they are 7"?
19th June 2016, 15:09
Hi Danny these look like the ones on my wifes classic mini the visor bit is separate and fits under the rim try Mini Spares at Potters Bar or Huddersfield Mini Spares i think they go for about £8 a pair if you have trouble getting them let me know and i will pick up a pair at the next mini show we go to
19th June 2016, 16:18
Ive found them on ebay by seatching '7" visor' but they are expensive @ £12 each
https://www.ebay.co.uk/itm/401105451669
19th June 2016, 22:11
try these eBay item number:131760594291
19th June 2016, 22:19
20th June 2016, 08:34
Thanks!
21st June 2016, 18:27
A copy of a copy cat idea
20160621_192402 by WCA!, on Flickr
24th June 2016, 14:15
Looks good wca do you do commission pieces?
24th June 2016, 14:57
Im looking for some advice! Ive been looking at the van for a while now and I dont think i need to spend £500 on a kit! The rear part of the kit wont fit anyway because its for a subaru sambar and not a hijet. The most importamt bit is the front......
How easy would it be for me to stip the front bumper etc off and make a metal fram and lay a big sheet of fiber glass over it to make the front flat like the vw and just cut the holes out for my lights?
Can anyone point me in te right direction here with what to use?
24th June 2016, 15:03
From this...
Really bad drawing but something like this....
24th June 2016, 15:05
The frame i can make no probs but was tjinking something like this? Or is there anything better what i should be using?....
https://www.ebay.co.uk/itm/322131344060
24th June 2016, 15:29
As you want a flat panel I would suggest using thin steel or ally sheet.
If you really want fibreglass then lay up on a glass pane to get your smooth flat finish
27th June 2016, 09:56
I can if you like. PM me. Samples of previous work
20160227_175111 by WCA!, on Flickr
20160322_181338 by WCA!, on Flickr
20160325_093852 by WCA!, on Flickr
I also have a Marylyn Monroe but can't find a picture of it so here is what it was based on instead
They are gradually getting better and my technique improves.
27th June 2016, 15:53
Are you scaling the headlights down or using vw units. 5 3/4 etc
27th June 2016, 17:32
7" mini lights
27th June 2016, 18:24
You can always trace over the photo and draw your extension on it. That's what i've been doing with photos of the progress of my build to see how it looks and gives you angles and reference points for measurements. And a tool to see the finished product. Usually side and front views will give a good 3d projection.
27th June 2016, 20:34
Danny
A guy in Thailand makes splitscreens on the multivan base
Im not suggesting you buy but if you go ahead fabricating your own it may inspire
https://www.facebook.com/photo.php?f...type=3&theater
30th June 2016, 12:33
