2nd May 2018, 12:40
rear bonded on
what a faff :0)
Rear bonding 3 by Muddy_B, on Flickr
rear bonding 1 by Muddy_B, on Flickr
Rear on now need to re-wire up rear lights.
2nd May 2018, 12:42
rear lights
wired up rear lights and need to re-test them. I used the same fog repeaters that Paul L used - seem to be just right.
Also dropped the rear which you can see in this pic. I need to double check heights - the gravel is on a small slope so its misleading. It will need lifting and balancing up for sure.
Rear view fog lights by Muddy_B, on Flickr
Next up is my saga on how I can add Empi spinners in a cheap as chips way (its all about solving problems) ....
2nd May 2018, 12:52
wheel centres
So anyone that knows me knows that I am fixated by using the Empi spinners I bought for the car - now they are by far the diameter at the screw fixing and I have had a few goes at finding a way to fix them.
Edit deleted as not relevant
Reason: .
3rd May 2018, 06:29
Keep plugging away Dave, you will work out the wheels issues no doubt.
You can always leave wheels for a few weeks, focus on the other stuff and the answer will usually creep up and tap you on the shoulder! Watching with interest, good progress so far tho!
3rd May 2018, 19:40
Thanks for the encouraging words. You’re right. I need to forget the wheel sizes as that is not finishing the bl@@dy car.
4th May 2018, 06:07
Originally Posted by DaveP
I see you are going for the Rover style continental boot mounted spare
4th May 2018, 07:26
I am !
You can never have too much rubber on the rear of your car...
6th May 2018, 07:06
Dave – Looks like you are making good progress and I’m glad the LED fog/reflectors were useful.
I actually quite like the plain steel wheels look, especially with the black gel coat, very Mad Max.
But I know you are going ‘purple’ so I’m sure whatever you think looks best will work.
6th May 2018, 15:10
Thanks Paul.
I have rather taken the mad max look on now. So the Kobra might stay black. At least through the summer while it is getting baked and settled.
I may even call the car Max. It didn’t get a name before now.
30th May 2018, 12:48
headlights and washers
headlights wired up using 7 core trailer wire
Untitled by Muddy_B, on Flickr
As were windscreen washers...
30th May 2018, 12:50
inner arches
fitted inner arches on fronts using 2mm polypropelene. Rears were the OEMS with a bit of cut and shutting
Inner Arch 1 by Muddy_B, on Flickr
30th May 2018, 12:53
stance adjustment
Took some pics as I was going to get the stance right on the coilovers
As you can see - I have embraced the ratty matt black look for the summer at least
30th May 2018, 12:56
plates on for now
Rear plates where I want them. Front plates I have attached to the front scuttle until I decide upon best grill.
I have purchased a new reg - that will get fitted once I have MOT - re-registered and re-insured
30th May 2018, 14:30
Looking good.
Add a few badges and it could be mistaken for "finished"...
30th May 2018, 15:39
Originally Posted by IanA
Looking good.
Thanks Ian,
There's the rub as I don't want to badge it. So it will always look unfinished
Considering my skills that's a theme I am going for.
That said I should have something on the bonnet that isn't just a terrible paint job !
Reason: .
30th May 2018, 15:50
The car brings a smile. Well done.
30th May 2018, 16:52
Ta very much
31st May 2018, 05:20
Dave – Your car looks great.
Is there much more to do before the MOT?
31st May 2018, 18:17
Paul thanks !
I have a list that may take 1-2 days. Booked in Monday !
Excited
31st May 2018, 18:39
Anyone having problems making a reply on the threads at the moment ??
