http://homepage.swissonline.ch/TomsS...tion2/Map.htm# was the page with all the detail on the 5AS and other ECU circuits but its gone off the net now.
I copied or printed most of the diagrams and have posted them on other forums including this one.
I made extensive hand drawn diagrams of all the circuits but they are a bit rough for anyone else to follow but they cover every circuit on the car and a few you will not have! I fitted waterproof sockets to the loom on both clams and fitted a working drivers door lock I also have activate key fobs and the a diag. socket as well as the immobiliser operating the hazards on lock and unlock.
![Bored](images/smilies/bored.gif)
I know a bit over the top perhaps for a kit car but I could so I did....
There is an extensive thread on the hazards on here I know because I contributed to it, the clue to remember there is that the hazard switch is the master switch for the indicators. The flashing signal is routed through the hazard switch and then on to the indicator switch. I also have clam open switches.
The 5AS and the ECU need to be a matched pair (key fob as well if you have it) either from the same car or programmed together, but I guess you know that.
There are a number of core between the two (ECU to 5AS), only two cores are required for basic operation the common earth and the serial link that tells the ECU to remove the immobiliser. You must put this common earth in or you will have problems.
If you want the ECU diag socket to work long term then more cores need to be made between them. You may regret not having the socket long term if things go wrong or you need to reset a MIL lamp.
An 'on' MIL would be an IVA fail for instance unless you dis the lamp.
I suggest you message me with an email address and I can ship them over to you.
You could try the Rover Forum for more information and detail.
That should keep you quiet for a day or two
![Jaw](images/smilies/jaw.gif)
enjoy.
Some odd bits that may not help
![Playball](images/smilies/playball.gif)
..... I have much more.
You will need a working driver side door lock to enter the test mode by the way. So may be out of your boundary of build.
5AS
I have got some notes, its for a 16k series.
Pin 1 Ignition supply
Pin 2 Earth
Pin 9 Imobiliser signal to ECU Pin 13
Pin 10 Antenna for remote.
Pin 23 Starter relay Pin 2
Pin 26 Battery supply.
Diagnostic Procedure
1. Close all doors and the tailgate.
NOTE: If the oil pressure switch goes open circuit (engine is started) during the following procedure, the MFU will exit the diagnostic mode immediately.
2. Press and hold the heated rear screen switch and switch on the ignition.
3. Release the heated rear screen switch within 2 seconds and the MFU will beep to indicate that it’s in
diagnostic mode 1.
4. Press the heated rear screen switch; the MFU will beep twice. In turn, operate each of the following
switches, heated front screen, rear fog guard lamps, side lights, headlights, front wiper and rear wiper.
The MFU will beep twice each time a switch is operated.
5. Pressing the heated rear screen again will cause the MFU to enter diagnostic mode 2.
6. The MFU will provide outputs to the following in order given below:
Heated rear screen relay energised for 2 seconds
Heated front screen energised for 2 seconds
Courtesy lights energised for 2 seconds
Dim dip relay energised for 2 seconds
Rear fog guard lamp energised for 2 seconds
Headlamp power wash energised for half a second
Front wiper energised for half a second
Rear wipe/wash energised for half a second
7. The MFU will then exit the diagnostic mode.
5AS Alarm Self Test Facility
Just found this procedure in an old Technical Bulletin (1995!).
It allows you to test all of the alarm's inputs. I have typed the details verbatim.
Access to the self test facility is obtained as follows:-
(The following steps 2 to 4, must be completed within 2 seconds, in order to induce the ECU to enter the self test mode.)
1) The vehicle must be in disarmed mode, unlocked and with the ignition switched off.
2) Lock the driver's door using the driver's door sill button.
3) Turn the ignition ON, OFF then ON again and leave it ON.
4) Unlock the driver's door using the driver's door sill button.
Confirmation that the test mode has been successfully entered is given by the horn sounding a short beep. Once in self test mode, the volumetric sensor (if fitted) is powered up and the vehicle is in an immobilised state.
If an ECU input is then seen to become active i.e. to go from an open circuit to a short circuit (or earthed) condition, the security LED will give a short flash to indicate this.
When the system is in the self test mode, operation of the appropriate switch by moving the associated panel or linkage will instigate the test on each of the following circuits;
1) Driver's door courtesy light switch.
2) Passenger door(s) courtesy light switch.
3) Bonnet open switch.
4) Boot open switch.
5) Driver's door key barrel switch. (Not on 100 models)
6) Boot key barrel switch (Not on 100 models)
7) Driver's sill button "up" switch.
8) Driver's sill button "down" switch.
Switch tests need not be made in any particular sequence and any or all may be tested as required.
Correct operation of the circuit being tested will be denoted by the single flash of the security LED and the same circuit may be tested repeatedly if necessary.
The self test mode can be terminated at any point by switching off the ignition.
Failure of the ECU to enter the test mode will probably indicate that it is not receiving inputs from either the ignition power supply or the driver's door sill button switches.
VOLUMETRIC TEST
The test facility may also be used to check the operation of the volumetric sensor, either ultrasonic or Doppler microwave (if fitted), by performing the following;
With the system in self test mode and the remote handset previously programmed and synchronised to the vehicle being tested, press the unlock button once.
The ECU will now disregard inputs from it's associated switches, and will instead, give a confirmation flash on the security LED to indicate that the volumetric sensor has been triggered, the action of which can usually be induced by waving a hand in front of the sensor.
The self test mode can be terminated by switching off the ignition.
